Motion Sensor Does not send Inactive status
Hello all,
I am just getting into the smartthings stuff and wanted to try my hand at creating a smartapp. Anyways this is very similar to what they do in the tutorial but mine doesn’t seem to be working. Long story short when my motion sensor goes inactive it does not send that event so that I can act upon it.
Below is my code:
preferences {
    section("When there's movement...") {
        input "motion1", "capability.motionSensor", title: "Where?", multiple: true
    section("Turn on a light...") {
        input "switch1", "capability.switchLevel", multiple: true
    section("Dimmer value in Day mode...") {
        input "dimmerDay", type: "number", title: "Dimmer value (1-99) for day mode", required: true
    section("Dimmer value in Night mode...") {
        input "dimmerNight", type: "number", title: "Dimmer value (1-99) for night mode", required: true
    section("Turn off light after...") {
        input "delay", type: "number", title: "Delay (in minutes) before turning off lights (0 is off)", required: true
def  turnOffRequests = 0
def installed()
    subscribe(motion1, "motion", motionHandler)
def updated()
    unsubscribe()
def motionHandler(evt) {
    log.debug evt.value
    if (evt.value == "active")
        log.debug "Calling motionActive"
        motionActive()
    else if (evt.value == "inactive")
        log.debug "Calling motionInactive"
        motionInactive()
def motionActive (){
    if (switch1.currentSwitch.contains("off"))
        sendNotificationEvent("Motion detected, turning on lights")
        def currMode = location.mode // "Home", "Away", etc.
        if (currMode == "Day")
            log.debug "Light is off and mode is " + currMode + " so setting to " + settings.dimmerDay + "%"
            switch1.setLevel(settings.dimmerDay)
        else
            log.debug "Light is off and mode is " + currMode + " so setting to " + settings.dimmerNight + "%"
            switch1.setLevel(settings.dimmerNight)
    else
        sendNotificationEvent("Motion detected but light is already on, doing nothing")
def motionInactive() {
    if (settings.delay != 0)
        turnOffRequests = turnOffRequests + 1
        sendNotificationEvent("Turning off lights in ${settings.delay} minutes.")
        def delaySeconds = settings.delay * 60
        runIn(delaySeconds, turnOff)
def turnOff()  {
    log.debug "turnOffRequests = " + turnOffRequests
    if (turnOffRequests == 1)
        switch1.setLevel(0)
    turnOffRequests = turnOffRequests - 1
Thanks,
Jon
You’re not alone I’m seeing the same exact issue
Thanks for the reply. At least I know that I am not the only one and not crazy!
Tagging @jody.albritton
I figured out my issue. Apparently I am not allowed to do the above. Found it in the documentation, now everything seems to be working as I expected.
Thanks,
Jon
