So I did all the steps, installed MariaDB, registered device handlers on ST IDE, created a smartapp and added it to the mobile app with all the correct addresses, and then went to Mi Conetor and filled the ID, URL and Token SmartThings fields.“test” returns OK
Fact is, Mi Conector only detects standalone Wifi Devices (lamps and robot) - the gateway and all the zigbee devices, are not detected.
I’ve also deleted a zigbee device and added it again on Mi Home to regenerate a token but still the same.
I restarted everything but not sure what else to do. Help please?
