Can you see from ST the instant power consumption? I would like to set up some automations in ST that are triggered if there is some consumption at the moment (TV ON) or if washing machine is over for example.
Unfortunately this is what I realized today as well. Power consumption doesnāt show on ST. I wrote to meross support but Iām not sure if I can get any result.
I would love to trigger some action based on that informationā¦
I have two Meross plugs which are always online and the smartthings automation have not missed a beat yet - touchwood. I emailed them last month asking if they would send an API to smartthings to include the power consumption / energy monitoring feature and they replied saying they donāt have any idea of doing this even in the near future. We are some unlucky folks till someone develops a DTH
If I want to allow SmartThings to access my Meross devices, I get the message: āNo such userā!
I use the meross-Device Username and password ā¦ Can you help me?
i got a couple meross plugs and power strip and set up native integration. Meross is showing devices as online but SmartThings sometimes shows them as offline. Is there anything i can do?
I find that if itās below 60 or 65% the device will disconnect and reconnect often and changes sent to it while disconnected donāt get synced once it reconnects.
This was the recommendation that meross sent me by mail some time ago
When you see one device offline, refresh the meross linked service:
see the menu of three parallel lines
click on the gear, top right
click on linked services and then on meross-c2c-pro
you will see all linked devices.
Exit this screen and they should already be online
If it happens to you very often, you may have to remove the meross linked service and add it again, but this is the last resource, since you would have to redo all the automations of these devices
thanks. i will try that. devices now all show online of course. It seems to be some timeout inactivity issue. Yesterday i turned on a specific device in Meross app, and it showed up as online in Smartthings but the rest were still showing offline.
