This is interesting.
Amazon has been gradually increasing the number of specific device models that could be used as triggers in their routines.
Originally, it was only some sensors, and then they added locks and some doorbells.
Very noticeably, they did not include switches or plugs, With some speculation that this might’ve been because many of the devices that they sell do not report a manual change in state to Alexa so they may just not have wanted the consumer support headaches of trying to explain why one light switch worked in a routine and another didn’t.
Anyway, Last December, they added pretty much anything connected to a Hue bridge to the available triggers for an Alexa routine, including the hue plug and friends of Hue light switches. And most of the buttons and remotes that could be connected to the Hue Bridge.
Amazon basic plugs also turned up sometime in the last year or so.
And now there are a bunch of new potential trigger candidates. Lots of ring devices, including the path lighting.
And… at least some matter Smart plugs, including the Tapo matter over wifi P125M models.
https://www.amazon.com/gp/product/B0BXMNJDW3/
At our house, this enabled us to create some additional proxy options for bringing non-matter devices into the Apple home app or SmartThings. For example, we have an automatic door opener which is controlled by BroadLink and appears as a light switch in Alexa. It does not support matter at this time.
To bring it into Apple Home, we are now using a Tapo Matter smart plug as a proxy.
The plug can be turned on or off in Apple home. And we can now use an Alexa routine as an intermediary, so when that plug turns on, an Alexa routine opens the door. This also lets me open the door with my Apple Watch.
The same method could be used to bring the door opener into SmartThings.
My guess is that matter devices update state, so Amazon now feels comfortable using them as triggers.
I don’t have any matter light switches: if someone does and also uses Alexa routines, could you check and see if that switch is now available as an Alexa routine trigger?
This would be another example of a useful feature from a matter integration.
