My apologies for the noob question.
I installed a Leviton DZ6HD a few weeks back as my first dimmer. It’s working fine, but doesn’t behave as I would expect under a specific scenario. Since it’s my first z-wave dimmer, I’m unsure if this is expected behavior or not.
When controlled from the switch, everything works properly, and when switched on it resumes at the set dimmer level.
However when controlled from the app, if I press the toggle switch to turn it on, it always sets the dimmer to 99%. The same behavior is experienced when I tell the Google Home to turn on the lights. I can work around by telling my Google Home to set the dimmer level, which will turn it on to the appropriate level, but it’s a little annoying.
When toggling on through the app, should the dimmer remember the last dim level, or does Smartthings “On” always equal 99%? I notice it’s using the Z-Wave Dimmer Switch Generic device handler, so maybe this is something that can be changed with a custom handler.
Any advice is appreciated.
