* Ubi Goodnight Check
* Author: seateabee@gmail.com
* Date: 2014-03-25
* This app uses three virtual tiles and any number of open/close sensors as well as
* lights. One virtual tile will be turned on by UBI, which still trigger the program
* to run. The three things will happen: A.) If any doors are open, the second virtual
* tile will be turned on. This will cause UBI to warn that a door is open. B.) If any
* windows are open, the third virtual tile will be turned on. This will cause UBI to
* warn that a window is open. C.) after a five minute wait, all specified lights and
* the three virtual devices will be turned off.
* What you need to do on the UBI side:
* - Setup your SmartThings as a device in thr Ubi Portal (still in Beta as of 3/25/14).
* - Create a custom behavior when you say a phrase (such as: Goodnight) that Ubi
* will turn the first Virtual Tile. (I also have Ubi say to me: "Checking windows
* and doors, turning off lights in 5 minutes" so I know Ubi heard me right.)
* - Create a custom behavior when virtual tile 2 turns on that Ubi will say:
* "You have a door open."
* - Create a custom behavior when virtual tile 3 turns on that Ubi will say:
* "You have a window open."
// Automatically generated. Make future change here.
definition(
name: "Ubi Goodnight Check",
namespace: "",
author: "seateabee@gmail.com",
description: "This app uses three virtual tiles and any number of open/close sensors as well as lights. One virtual tile will be turned on by UBI, which still trigger the program to run. The three things will happen: A.) If any doors are open, the second virtual tile will be turned on. This will cause UBI to warn that a door is open. B.) If any windows are open, the third virtual tile will be turned on. This will cause UBI to warn that a window is open. C.) after a five minute wait, all specified lights and the three virtual devices will be turned off.",
category: "Convenience",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience%402x.png"
preferences {
section("Which Virtual Switch is the Trigger?") {
input "trigger", "capability.switch", title: "Which?"
section("Which Virtual Switch is the Door Check?") {
input "doorCheck", "capability.switch", title: "Which?"
section("Which Virtual Switch is the Window Check?") {
input "windowCheck", "capability.switch", title: "Which?"
section("Which light switches will I be turning off?") {
input "theSwitches", "capability.switch", Title: "Which?", multiple: true, required: false
section("Which doors should I check?"){
input "doors", "capability.contactSensor", title: "Which?", multiple: true, required: false
section("Which windows should I check?"){
input "windows", "capability.contactSensor", title: "Which?", multiple: true, required: false
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
subscribe(trigger, "switch.on", switchOnHandler)
def switchOnHandler(evt) {
checkDoors()
checkWindows()
runIn (300, lightsOut)
def checkDoors() {
def open = doors.findAll { it?.latestValue("contact") == "open" }
if(open) {
doorCheck.on()
def checkWindows() {
def open = windows.findAll { it?.latestValue("contact") == "open" }
if(open) {
windowCheck.on()
def lightsOut() {
trigger.off()
doorCheck.off()
windowCheck.off()
theSwitches.off()
This is an app I created for use with my Ubi. It performs a similar function: When I say ‘goodnight’ to Ubi, it check all included door and window sensors. The app is activated by UBI turning on a virtual switch. If a door or window is open, the app turns on another virtual switch. Ubi is set to watch for this switch turn on, and if it does, then it says: “Wait, a door (or window) is open!”
You should be able to adapt this relatively easily. Have a switch set so that as soon as mode is changed to away, it turn on the switch. Can instead of turn on other virtual switches, it sends a text message or whatever notification you want.
