I have a SmartApp that looks at recent events to see if a device is communicating with the SmartThings hub. I used to have events listed in the IDE under the “all” subheading for a device that would have a value of isStateChange = false and they would be greyed out. I could pull these events with a SmartApp with the following:
device.events([all: true, max: 100])
This was extremely useful because I have some devices that mostly report battery level (water sensor for example), but the battery level does not change very often. So in the event feed I would see:
battery 90% isStateChange = false
battery 90% isStateChange = true
battery 91% isStateChange = false
Those events are no longer being recorded (unless the device is a switch?) which is extremely problematic for my SmartApp. How am I supposed to check if a device is “alive” if it’s communication with the hub is being discarded? Is this something that was changed recently or something that I have missed? Here is a picture of what I am expecting to see, but I am only seeing the events that are not greyed out:
