I have a logitech harmony elite(Harmony Hub and remote) and phillips hue lights. On the harmony I have 1 simple activity: watch TV
When the watch TV activity is triggered it turns on my TV, HTPC(home theater PC), lights and tune to a specify TV channel.
What I would like to do:
when I leave home or going to sleep is to turn off the lights and TV but keep the HTPC on
turn on the lights and TV when I arrive home
I known I can turn off the lights at a specific time using different apps, but I’m not sure how to turn off the TV automatically since it’s tied to an activity. Would having a SmartThing hub solve the problem?
I do something similar. I have a good night routine that executes the turn off command on the TV. If you have it set up to never turn off the HTPC in harmony it will just shut down the TV. I leave my HTPC on all the time.
You can control Harmony actions like light switches in ST. So you should be able to trigger Watch TV and turn on lights when you come home. I have lights trigger when I come home.
If you want a device you could do this with SmartThings, but it would actually be a bit easier to do it with the free IFTTT service. You don’t need any extra devices at all. Harmony and Phillips already have IFT TT channels, and you can also use your phone’s presence.
Yonomi is a free app which can also do the same thing. Some people find it it runs somewhat faster than IFTTT does although it has fewer device partners. It should work for the case you described, though.
Whichever way you do it, the first step is to have a harmony activity which does exactly what you want. Because all that SmartThings or IFTTT or Yonomi will do is trigger that harmony activity.
In your case, I would think the simplest thing would be just to define your HTPC as an “always on” device in harmony. Once you do that, turning off the activity does not turn off that particular device. That’s what people do for cable set top boxes so that their video recordings will still take place even when the rest of the home entertainment system is turned off.
