Is “between” supposed to trigger?
I wrote a Rule that will set the Location mode and Home Monitor state according to time of day and who is/isn’t home. In one of the nests “if” has a between with 2 times. This doesn’t seem to trigger at either the start or end times, but will execute properly if one of the other “if”s trigger so I am guessing , no
I think, I need to “or” that between with 2 other “equals” to tigger at that start or end time, any inputs?
I use “between” with “changes” to make it trigger, otherwise it always seems to act as a precondition.
@AZSteve Always good if you can attach a screenshot of your Rule so we can see how you set it up. Blackout any info you don’t wish to be seen online. :slight_smile:
Yup, between time ranges just seem to act as a pre-condition rather than a trigger.
@jkp, here is the Rule. I suspect that @sipuncher is correct
	"name": "Location Mode Updater (Mode)",
	"actions": [
			"if": {
				"equals": {
					"left": {
						"device": {
							"devices": [
								"74a67738-af98-4089-af9e-c17b811c47ab",
								"ef2bcbf9-ca11-421a-88f7-2c9b9702f219"
							"component": "main",
							"capability": "presenceSensor",
							"attribute": "presence",
							"trigger": "Always"
					"right": {
						"string": "not present"
					"aggregation": "All"
				"then": [
						"location": {
							"security": {
								"armState": "ArmedAway"
						"location": {
							"mode": "99d86a45-853e-49e1-9129-72493ab0153c"
				"else": [
						"if": {
							"between": {
								"value": {
									"time": {
										"reference": "Now"
								"start": {
									"time": {
										"reference": "Noon",
										"offset": {
											"value": {
												"integer": 11
											"unit": "Hour"
								"end": {
									"time": {
										"offset": {
											"value": {
												"integer": -5
											"unit": "Hour"
							"then": [
									"location": {
										"security": {
											"armState": "ArmedStay"
									"location": {
										"mode": "3f8418ca-1beb-474c-9640-fd2e013a94b2"
							"else": [
									"location": {
										"security": {
											"armState": "Disarmed"
									"location": {
										"mode": "39d2fbe6-c52b-4097-9115-85cc03c54c4c"
to catch the 11pm time, i modified the Rule today like this… i then added another If\equals in the same Rule as an additional Action to catch the 7am time
	"actions": [
			"if": {
				"or": [
						"equals": {
							"left": {
								"datetime": {
									"reference": "Now"
							"right": {
								"datetime": {
									"offset": {
										"value": {
											"integer": 11
										"unit": "Hour"
						"between": {
							"value": {
								"time": {
									"reference": "Now"
							"start": {
								"time": {
									"offset": {
										"value": {
											"integer": 11
										"unit": "Hour"
							"end": {
								"time": {
									"offset": {
										"value": {
											"integer": -5
										"unit": "Hour"
				"then": [
						"location": {
							"security": {
						"location": {
				"else": [
						"if": {
							"between": {
								"value": {
									"time": {
										"reference": "Now"
								"start": {
									"time": {
										"offset": {
											"value": {
												"integer": 11
											"unit": "Hour"
								"end": {
									"time": {
										"offset": {
											"value": {
												"integer": -5
											"unit": "Hour"
							"then": [
									"location": {
										"security": {
									"location": {
							"else": [
									"location": {
										"security": {
									"location": {
and the additional if\equals
			"if": {
				"and": [
						"equals": {
							"left": {
								"datetime": {
									"reference": "Now"
							"right": {
								"datetime": {
									"offset": {
										"value": {
											"integer": -5
										"unit": "Hour"
						"equals": {
							"left": {
								"device": {
									"devices": [
									"trigger": "Always"
							"right": {
								"string": "present"
				"then": [
						"location": {
							"security": {
						"location": {
i tried the changes
between
	"if": {
		"changes": {
			"between": {
				"value": {
					"time": {
						"reference": "Now"
				"start": {
					"time": {
						"offset": {
							"value": {
								"decimal": 11
							"unit": "Hour"
				"end": {
					"time": {
						"offset": {
							"value": {
								"decimal": -5
							"unit": "Hour"
		"then": [
				"location": {
					"security": {
				"location": {
		"else": [
				"location": {
					"security": {
				"location": {
that didn’t work.
I then tried ‘between’, which will work, if something else triggers… so it is definitely a pre-condition, but i coupled that with 2 every specific, these don’t seem to trigger at the time either.
	"actions": [
			"every": {
				"specific": {
					"offset": {
						"value": {
							"decimal": 11
						"unit": "Hour"
				"actions": [
						"location": {
							"security": {
						"location": {
			"every": {
				"specific": {
					"offset": {
						"value": {
							"decimal": -5
						"unit": "Hour"
				"actions": [
						"location": {
							"security": {
						"location": {
			"if": {
				"equals": {
					"left": {
						"device": {
							"devices": [
								"a22fffbe-f6d0-427b-bf48-9746e5545216"
							"capability": "switch",
							"attribute": "switch",
							"trigger": "Always"
					"right": {
						"string": "on"
				"then": [
						"location": {
							"security": {
						"location": {
							"mode": "cf17bc21-d3c2-4f69-8443-752acac57cec"
				"else": [
						"if": {
							"equals": {
								"left": {
									"device": {
										"devices": [
										"trigger": "Always"
								"right": {
							"then": [
									"location": {
										"security": {
									"location": {
							"else": [
									"if": {
										"between": {
											"value": {
												"time": {
													"reference": "Now"
											"start": {
												"time": {
													"offset": {
														"value": {
															"decimal": 11
														"unit": "Hour"
											"end": {
												"time": {
													"offset": {
														"value": {
															"decimal": -5
														"unit": "Hour"
										"then": [
												"location": {
													"security": {
												"location": {
										"else": [
												"location": {
													"security": {
												"location": {
This works for me.
  "if": {
    "changes": {
      "between": {
        "value": {
          "device": {
            "devices": [
              "780be2dd-29f0-4647-b5a1-3189751f2bc1"
            "capability": "temperatureMeasurement",
            "attribute": "temperature"
        "start": {
          "decimal": 23
        "end": {
          "decimal": 80
thanks @mrfitz98 , that didn’t seem to work, not sure if it is because it’s nested
if(VACATION BUTTON= ON) -> set VACATION mode and ARMED(Away)
    else if Everyone is Away -> set AWAY mode and ARMED(Away)
        else if time changed\between 11pm and 7 am  -> set NIGHT mode and ARMED(Stay)
           else -> set HOME mode and DISARMED
i did ultimately get it to work, although i don’t think it’s optimal as i had to repeat all the conditions
	"actions": [
			"every": {
				"specific": {
					"offset": {
						"value": {
							"decimal": 11
						"unit": "Hour"
				"actions": [
						"if": {
							"equals": {
								"left": {
									"device": {
										"devices": [
										"trigger": "Always"
								"right": {
									"string": "on"
							"then": [
									"location": {
										"security": {
									"location": {
							"else": [
									"if": {
										"equals": {
											"left": {
												"device": {
													"devices": [
													"trigger": "Always"
											"right": {
										"then": [
												"location": {
													"security": {
												"location": {
										"else": [
												"location": {
													"security": {
												"location": {
			"every": {
				"specific": {
					"offset": {
						"value": {
							"decimal": -5
						"unit": "Hour"
				"actions": [
						"if": {
							"equals": {
								"left": {
									"device": {
										"devices": [
										"trigger": "Always"
								"right": {
									"string": "on"
							"then": [
									"location": {
										"security": {
									"location": {
							"else": [
									"if": {
										"equals": {
											"left": {
												"device": {
													"devices": [
													"trigger": "Always"
											"right": {
										"then": [
												"location": {
													"security": {
												"location": {
										"else": [
												"location": {
													"security": {
												"location": {
			"if": {
				"equals": {
					"left": {
						"device": {
							"devices": [
							"trigger": "Always"
					"right": {
						"string": "on"
				"then": [
						"location": {
							"security": {
						"location": {
				"else": [
						"if": {
							"equals": {
								"left": {
									"device": {
										"devices": [
										"trigger": "Always"
								"right": {
							"then": [
									"location": {
										"security": {
									"location": {
							"else": [
									"if": {
										"between": {
											"value": {
												"time": {
													"reference": "Now"
											"start": {
												"time": {
													"offset": {
														"value": {
															"decimal": 11
														"unit": "Hour"
											"end": {
												"time": {
													"offset": {
														"value": {
															"decimal": -5
														"unit": "Hour"
										"then": [
												"location": {
													"security": {
												"location": {
										"else": [
												"location": {
													"security": {
												"location": {
You’re right, I had to pull the “changes” trigger out of my 3 condition statements to be able to have it trigger.
if changes
then
if the other conditions
then actions
When I had my “changes” lumped in with my other conditions it didn’t trigger. In my case I also have a “changes not between” in my “else” to flip it back if it falls out of the target range. I use this to open or close my shades depending on the temperature.
