IFTTT How to Set Up
Anyone know how to set up IFTTT to call you if your smartthings alarm goes off? I did some research and it states I need to make a virtual switch but can find any simple directions to follow.
Here is a FAQ on installing virtual devices.
You’ll want to create a Momentary Button Tile, so it always triggers on.
Then in SHM under Turn on Lights, you’ll add your virtual button
From there you can go into IFTTT and add the rule that IF that switch is turned on, THEN call your phone
