I have a SmartThings motion/temp sensor on the back door.Is it possible to set up a push notification if the back door is open and the temperature is less than 16’C?
I can set up a push notification if either of these things happen individually easy enough, just cant figure out how to send a message only if BOTH conditions are met.
Yes, thanks @ady624 and @PhilB for the shoutout. SmartRules can definitely handle that. As Phil mentioned, if you only need this one rule, it’s free! Let me know if you have any questions.
No, there is no need to deactivate it, though it is already sidelined, only receives critical updates. So while I would strongly recommend against using it, people are free to use it
