I created an Edge Driver for the Shelly BLU RC Button 4 ZB
Hi All,
I’ve created a working driver for the Shelly device since i could not find one at all. It’s working quite well. I have no idea how to share it on the community drivers subscriptions, but have the zip package with all the necessary files that installs perfectly via the CLI.
anyone interested?
Sam
Create invitation
and share Accept URL to community
Install the Shelly BLU RC Button 4 Edge Driver
Accept the SmartThings driver channel invitation here:
After accepting the invitation, select Available Drivers, then install the Shelly BLU RC Button 4 driver on your SmartThings hub.
Source code:
I attempted to correct the original post, let me know if i got it right now! Thank you for the assist. Sam
FYI: Your link to the driver is working correctly.
Awesome, thank you for confirming
Amazing work here, thank you! I have it installed and working perfectly.
I think your driver would work with this Shelly device as well.
Shelly BLU Wall Switch 4 ZB Standalone | Shelly Europe
Could you add this device’s fingerprints to your driver
manufacturer: Shelly
model: BLU Wall Switch 4 ZB
These are probably the fingerprints. I don’t have this device.
Shelly BLU Wall Switch 4 ZB | Shelly Technical Documentation
Hello,
Thank you for the suggestion. I don’t have that device either. I’d rather not add the fingerprint unless I’ve tested it specifically. That being said, the code is on GitHub if someone that has it wants to try!
Cheers,
Sam
Thanks a lot. I have installed, works very well with my Shelly BLU RC Button 4 ZB. It was real issue for me.
Just curious, how are you communicating with Bluetooth devices from SmartThings?
Hello All, the driver is using Zigbee, not BT. Problem was that the original edge driver did not expose the button functions, so i created a new one that did. Using Zigbee, not BT.
I’m not using smartthings anymore, mostly ported over to Home Assistant now and this button is supported in HA without having to create a new driver.
Sam
