Hello every one. I bough a smartthings hub and I have some zwave Fibaro switchs. How I can connect hub with Fibaro switch?
Thanks all you.
Thanks all you.
Power it up and connect to your network and register it.
On you mobile app under the things tab you will see add a thing.
Press that and as its a Fibaro device, press the ’ B’ button 3 times (as per instructions manual) and it should connect.
Thanks Bob. Let me try it.
