pizzinini
(Pizzinini)
April 12, 2016, 1:40pm
3
Have you looked at this? The app is pretty easy to configure but you will need some additional hardware. Dependent on how many vents you have this may be cheaper or more expensive than a 2-zone damper.
Introducing Keenect, a vent management smartApp for your Keen vents.
Keenect a clean slate design, event driven vent and zone management smartApp.
It is a parent/child application consisting of:
–Keenect, the parent, which responds to changes made to your main HVAC thermostat, distributing these events to
–keenectZone, the child app, which then controls your vents based on local temperature conditions and your selected temperature set points.
–A keenectZone consists of one or more Keen vents and a temperature sensor.
[image] [image]
What it can do:
Even out temperature variations across your configured zones
Disable or enable any zone from other smartApps
Allows separate and independent heating and cooling settings for each zone
Supports C and F temperature scales automatically
Pre…
