HUB Location
My main router (from verizon) and switchesare located in the garage in a server rack, from there I usually run the cables towards inside the house through the attic, Does the HUB has to be inside the house to work properly or can I leave it in the garage?
It might work fine where it is but it’s always best to move it away from any other wireless emitting device (hotspots, routers etc) as they can interfere with each other.
Also the ST Hub often performs better in a central location (from what I’ve found) as you will have potentially less hops to your devices.
Kraeg
Thanks for the reply. can the hub be on by POE? It would be nice to mount it in the ceiling of my hallway
Not directly to the network no, but people have done it another way:
