Hub Firmware Upgrade 16.13 BROKE Functionality
Just coming in here, but my first thought would be to check the IFTTT integration before doing anything with echo.
So:
One) create a new Do button in IFTTT that just unlocks the lock in The SmartThings channel/service. ( this is the simplest troubleshooting test, because there is no “if,” there is just a “that.”)
If you haven’t use the Ifttt DO Button before, then you will have to download that app.
“Button” in this context just means a widget that will appear on your phone, it’s not a physical button.
  1. if you are able to select your lock for the DO Button and pressing the DO Button on your phone causes the lock to unlock, then you know the basic IFTTT functionality has not been affected.
If you are not able to get the door to unlock when you press the Do button on your phone, or if you are not able to create a DO Button applet for the lock to begin with, then you know the issue is either with IFTTT or with the SmartThings service/channel in IFTTT.
A separate note about Alexa and Locks
For those who are confused about Alexa and locks, I would note that the OP says they have been using IFTTT. Those who have only been using the SmartThings integration may not be familiar with how this works.
If you use the echo IFTTT service/channel as the If, there is then no Alexa restriction on what devices you can trigger as the “that.” (There may be individual restrictions by the That service/channel, but SmartThings doesn’t have one.)
So you’ve always been able to say “Alexa, trigger lock the front door” or “Alexa, trigger good night” or any other phrase you wanted and control a lock through the SmartThings IFTTT channel/service, as long as you used the “trigger” phrasing and set it up through the echo IFTTT channel rather than the Echo/SmartThings direct integration.
I would also note that several other community members have reported weird things happening with their echo integration in the last few days. So anything is possible.
