Hello, I was trying to control some devices with HTTPS API in my local network using virtual switches. I’ve seen examples for http requests using HubAction. Is there any way I can send the requests using https? Certificate validation isn’t necessary (same as ‘curl -k’). I don’t want to expose the IPs to the WAN.
Is there any way to achieve what I want? Thank you.
Considering the hub and your devices are all in your LAN, why do you need HTTPS? You don’t need to expose ports to the WAN.
That said, I did try in the past making https hubactions work, but I failed. There may well be a way to do it.
I do this in my unofficial Samsung Audio integration using HubAction. It comes across the LAN as a HTTP (vice HTTPS). See thread: {BETA} Samsung Audio including TTS with Voices
The command path is:
smartPhone -> SmartThings ‘Device’ -> SmartThings Hub -> device
Response path is: device -> SmartThings Hub -> SmartThings ‘Device’ ‘action’ parse method.
The Setup:
def on() {
SetPowerStatus("1")
sendEvent(name: "switch", value: "on")
play()
updateDisplay()
The device-code (already in url format).
def SetPowerStatus(powerStatus, action = "generalResponse") {
sendCmd("/UIC?cmd=%3Cname%3ESetPowerStatus%3C/name%3E" +
"%3Cp%20type=%22dec%22%20name=%22powerstatus%22%20val=%22${powerStatus}%22/%3E",
action)
The hub-action command
private sendCmd(command, action){
def deviceIP = getDataValue("deviceIP")
def cmdStr = new physicalgraph.device.HubAction([
method: "GET",
path: command,
headers: [
HOST: "${deviceIP}:55001"
null,
[callback: action]
sendHubCommand(cmdStr)
Dave
The devices have only HTTPS API? I have no control over it. I need a chain of GET/PUTs to the devices to do the tasks I want, which I am now doing from AWS Lambda using port forwarding, but the latency is too long for my taste.
I thought doing the exchanges locally would make it much faster.
Thanks Dave, I tried this example. It works with a HTTP endpoint. But with my devices, the callback method is never invoked since they only respond to HTTPS.
I have a device handler - smaart app combo that uses node.js on the my LAN. Requires a “server - hub” running the Node.js app. This could do it for you and I have the base code (for TCP (Node.js also supports HTTPS). Example is at
The path is simple: phone App -> SmartThings Cloud -> hub -> node.js server (using HTTP) -> device
Then reversed. You could do the reverse path.
I also have some depreciated code that provided the bridge only.
These were developed because hubAction does not support TCP nor UDP (sound familiar?). Maybe this will help.
