Thanks for the help given here - it’s a great community!
With the help from here, I have completed the app to my requirements now and here is a link should anyone else be remotely interested in this functionality - it’s very simple (not a bad thing sometimes with code!) and does the job well.
* Trigger Motion Sensor from Virtual Switch
* Copyright 2015 James Houghton
* Description
* This simple SmartApp is designed to take an activation of a (Simulated/Virtual) Switch (for example, triggered by IFTTT) and create
* an event similar to that of a motion sensor. My first very quick and dirty app (a SmartThings version of Hello World - without
* the actual message!) which could be used in the "use case" below.
This file has been truncated. show original
