I am a new user for the smart hing hub. I wonder is there a way to set up a notification such that it is only triggered when device 1 is triggered first, and then device 2 is trigger with certain time frames?
I have experienced some motion sense false alarm, so I would like to use two event sequential trigger to avoid some false alarms to me.
Using custom code is pretty straightforward, basically you copy the authorās code and paste it into your own account. The following FAQ will describe the process and should answer most of your questions.
Then if you decide thatās something youād like to move forward with, you can ask any follow-up questions in the authorās thread for the specific code youāre considering using and people there will be able to help you.
You can also use CoRE as it has an IF construct that follows a sequential path to an action.
THEN IF - All conditions/triggers are evaluated in a sequence. Each action is evaluated only if the previous one was true. The group is true when all conditions are true.
Or
FOLLOWED BY - This is a ladder type evaluation, where each piston evaulation may advance the ladder to the next step, if that step is true. If the current step the ladder is at evaluates as false, the whole ladder is reset and the result is false. The result will be true only when the last condition is reached and that evaluates true, at which point the ladder is again reset and ready for the next cycle.
