Hi Guys,
How to get the list of devices that paired into the hub from coding prospective?
I mean by using Groovy, is there any API for this one?
Hi Guys,
I would recommend taking a read through the docs.
http://docs.smartthings.com/en/latest/index.html
If you haven’t already, start with the introductory docs to understand some of the concepts specific to SmartThings and then the section on selecting devices is:
http://docs.smartthings.com/en/latest/smartapp-developers-guide/devices.html
Note that a SmartApp typically selects devices based on the capability. For example, you might ask for all capability.switch devices to get all devices that can switch on/off.
Yeah, I read that.
I mean is there any API that able to list all the devices that paired on the SmartThing’s Hub
like getHubDevices()
and the return would be
{SmartSense, Zwave-Contact Sensor, Philip Hue}
Got it, all fall under ${settings}
As you found, all devices that the user selected during installation of the SmartApp are stored in settings (along with all other user inputs).
You cannot get info or a list of a devices that the user did not authorize/select in a SmartApp. This is by design; SmartApps only have access to those devices specifically authorized by the end user.
