Help Needed: SmartThings Edge Driver Fails to Reflect Cooling Setpoint & Temperature
I created an Edge driver for a Samsung mini-split AC with the latest capabilities. While AC mode, fan operation, and switch control work correctly, I’m facing an issue with simulating the cooling setpoint and temperature. The JSON payload is being accepted by SmartThings but the updates are not reflected on the device.
Since I couldn’t make my Edge driver discoverable, I used Tasutin’s Edge Driver V2 devices to create a virtual AC (as it’s hosted on the cloud). My plan is to later switch it over to my driver. However, when switching, the provisioning state remains stuck at Driver_Switch instead of changing to TYPED.
As mentioned, everything else works fine except for temperature simulation and cooling setpoint. Although the values are accepted, they are not being applied to the device. I’ve also observed the same behavior through the SmartThings CLI.
Could you please help me resolve this issue?
So… You can control the actual device with your driver?
I might be wrong, but the Samsung ACs are directly connected devices…
No, it’s not.
Can you please post the init.lua of your driver? Add ``` before and after the code.
Edit: skip the next comment - formatted code below.
this is my int.lua
– Samsung Mini Split AC Edge Driver
-- Author: Ashwin
-- Date: August 12, 2025
local capabilities = require “st.capabilities”
local Driver = require “st.driver”
local log = require “log”
-- Driver constants
local DEVICE_PROFILE = “samsung-mini-split”
-- Initialize device with default attribute values
local function initialize_device(device)
log.info("Initializing Samsung Mini Split AC device: " .. device.device_network_id)
– airConditionerFanMode - Set default values as specified
device:emit_event(capabilities.airConditionerFanMode.fanMode(“medium”))
device:emit_event(capabilities.airConditionerFanMode.supportedAcFanModes({“auto”,“low”,“medium”,“high”,“turbo”}))
device:emit_event(capabilities.airConditionerFanMode.availableAcFanModes({“auto”,“low”,“medium”,“high”,“turbo”}))
– airConditionerMode - Set default values as specified for Lennox powered Samsung mini split
device:emit_event(capabilities.airConditionerMode.airConditionerMode(“cool”))
device:emit_event(capabilities.airConditionerMode.supportedAcModes({“auto”,“cool”,“dry”,“fan”,“heat”}))
device:emit_event(capabilities.airConditionerMode.availableAcModes({“auto”,“cool”,“dry”,“fan”,“heat”}))
– fanOscillationMode - Set default values as specified
device:emit_event(capabilities.fanOscillationMode.fanOscillationMode(“fixed”))
device:emit_event(capabilities.fanOscillationMode.supportedFanOscillationModes({“fixed”,“vertical”,“horizontal”,“all”}))
device:emit_event(capabilities.fanOscillationMode.availableFanOscillationModes({“fixed”,“vertical”,“horizontal”,“all”}))
– temperatureMeasurement - Set default temperature to 77°F
device:emit_event(capabilities.temperatureMeasurement.temperature({value = 77, unit = “F”}))
– thermostatCoolingSetpoint - Set default cooling setpoint and range
device:emit_event(capabilities.thermostatCoolingSetpoint.coolingSetpoint({value = 69, unit = “F”}))
device:emit_event(capabilities.thermostatCoolingSetpoint.coolingSetpointRange({minimum = 61, maximum = 86, step = 1, unit = “F”}))
– switch capability - default to off
device:emit_event(capabilities.switch.switch(“off”))
log.info(“Samsung Mini Split AC device initialized successfully”)
end
-- Handle device added
local function device_added(driver, device)
log.info("Device added: " .. device.device_network_id)
end
-- Handle device initialization
local function device_init(driver, device)
log.info("Device init: " .. device.device_network_id)
end
-- Handle driver initialization
local function driver_init(driver)
log.info(“Samsung Mini Split AC Driver initialized”)
log.info(“Driver capability handlers registered:”)
log.info("- Switch capability: " .. tostring(capabilities.switch.ID))
log.info("- AC Mode capability: " .. tostring(capabilities.airConditionerMode.ID))
log.info("- Cooling Setpoint capability: " .. tostring(capabilities.thermostatCoolingSetpoint.ID))
– Run discovery immediately when driver starts
discovery_handler(driver, {}, function() return false end)
end
-- Handle switch on command
local function handle_switch_on(driver, device, command)
log.info(“Handling switch on command”)
device:emit_event(capabilities.switch.switch(“on”))
– When turning on, ensure we have the proper AC mode and fan mode
end
-- Handle switch off command
local function handle_switch_off(driver, device, command)
log.info(“Handling switch off command”)
end
-- Handle air conditioner mode change for Lennox powered Samsung mini split
local function handle_ac_mode_change(driver, device, command)
local mode = command.args.mode
log.info("Changing AC mode to: " .. mode)
local supported_modes = {“auto”, “cool”, “dry”, “fan”, “heat”}
– Validate the mode
for _, supported_mode in ipairs(supported_modes) do
if supported_mode == mode then
  device:emit_event(capabilities.airConditionerMode.airConditionerMode(mode))
  -- If switching to a mode, ensure the unit is on
  device:emit_event(capabilities.switch.switch("on"))
  return
end
end
log.warn("Unsupported AC mode: " .. mode)
end
-- Handle fan mode change
local function handle_fan_mode_change(driver, device, command)
local fan_mode = command.args.fanMode
log.info("Changing fan mode to: " .. fan_mode)
local supported_fan_modes = {“auto”, “low”, “medium”, “high”, “turbo”}
– Validate the fan mode
for _, supported_mode in ipairs(supported_fan_modes) do
if supported_mode == fan_mode then
  device:emit_event(capabilities.airConditionerFanMode.fanMode(fan_mode))
  -- If changing fan mode, ensure the unit is on
  return
end
end
log.warn("Unsupported fan mode: " .. fan_mode)
end
-- Handle fan oscillation mode change
local function handle_oscillation_mode_change(driver, device, command)
local oscillation_mode = command.args.fanOscillationMode
log.info("Changing oscillation mode to: " .. oscillation_mode)
local supported_oscillation_modes = {“fixed”, “vertical”, “horizontal”, “all”}
– Validate the oscillation mode
for _, supported_mode in ipairs(supported_oscillation_modes) do
if supported_mode == oscillation_mode then
  device:emit_event(capabilities.fanOscillationMode.fanOscillationMode(oscillation_mode))
  return
end
end
log.warn("Unsupported oscillation mode: " .. oscillation_mode)
end
-- Handle cooling setpoint change
local function handle_cooling_setpoint_change(driver, device, command)
log.info(“=== COOLING SETPOINT HANDLER CALLED ===”)
log.info("Command received: " .. (command and “YES” or “NO”))
log.info("Command args: " .. (command.args and “YES” or “NO”))
local setpoint = command.args.setpoint or command.args.value
log.info("Raw setpoint value: " .. tostring(setpoint))
log.info("Setpoint type: " .. type(setpoint))
log.info("Changing cooling setpoint to: " .. setpoint .. “°F”)
– Validate setpoint is within range (61-86°F)
if setpoint and setpoint >= 61 and setpoint <= 86 then
log.info("Setpoint is within valid range, emitting event...")
-- Try different emission formats
local temp_event = capabilities.thermostatCoolingSetpoint.coolingSetpoint({value = setpoint, unit = "F"})
log.info("Event object created: " .. tostring(temp_event))
device:emit_event(temp_event)
log.info("Cooling setpoint event emitted successfully")
-- Also try emitting without unit
device:emit_event(capabilities.thermostatCoolingSetpoint.coolingSetpoint(setpoint))
log.info("Alternative cooling setpoint event emitted")
-- If changing setpoint, ensure the unit is on and in cool mode
device:emit_event(capabilities.airConditionerMode.airConditionerMode("cool"))
log.info("Switch and AC mode events emitted")
else
log.warn("Setpoint out of range or missing: " .. tostring(setpoint) .. " (valid range: 61-86°F)")
end
log.info(“=== COOLING SETPOINT HANDLER COMPLETED ===”)
end
-- Handle refresh command
local function handle_refresh(driver, device, command)
log.info(“Refreshing device state”)
end
-- Device discovery function
local function discovery_handler(driver, opts, should_continue)
log.info(“Starting Samsung Mini Split AC discovery”)
– Create a mock device for demonstration
– In a real implementation, this would scan for actual devices
local device_metadata = {
type = "LAN",
device_network_id = "samsung-mini-split-001",
label = "Samsung Mini Split AC",
profile = DEVICE_PROFILE,
manufacturer = "Samsung",
model = "Mini Split AC",
vendor_provided_label = "Samsung Mini Split Air Conditioner"
log.info("Creating Samsung Mini Split AC device with metadata: " .. device_metadata.device_network_id)
local device = driver:try_create_device(device_metadata)
if device then
log.info("Successfully created Samsung Mini Split AC device")
else
log.error("Failed to create Samsung Mini Split AC device")
end
end
-- Create the driver
local samsung_mini_split_driver = Driver(“SamsungMiniSplitDriver”, {
discovery = discovery_handler,
lifecycle_handlers = {
init = driver_init,
added = device_added,
driverSwitched = device_init
capability_handlers = {
\[capabilities.switch.ID\] = {
  \[capabilities.switch.commands.on.NAME\] = handle_switch_on,
  \[capabilities.switch.commands.off.NAME\] = handle_switch_off
\[capabilities.airConditionerMode.ID\] = {
  \[capabilities.airConditionerMode.commands.setAirConditionerMode.NAME\] = handle_ac_mode_change
\[capabilities.airConditionerFanMode.ID\] = {
  \[capabilities.airConditionerFanMode.commands.setFanMode.NAME\] = handle_fan_mode_change
\[capabilities.fanOscillationMode.ID\] = {
  \[capabilities.fanOscillationMode.commands.setFanOscillationMode.NAME\] = handle_oscillation_mode_change
\[capabilities.thermostatCoolingSetpoint.ID\] = {
  \[capabilities.thermostatCoolingSetpoint.commands.setCoolingSetpoint.NAME\] = handle_cooling_setpoint_change
\[capabilities.refresh.ID\] = {
  \[capabilities.refresh.commands.refresh.NAME\] = handle_refresh
-- Run the driver
samsung_mini_split_driver:run()
I don’t have project access for Taustin’s workspace , i have access only for the driver channel
got it from Youtube Youtube
Channel Invitation for Edge Driver: https://api.smartthings.com/invitatio…
Readable:
-- Author: Ashwin
-- Driver constants
  log.info(“Samsung Mini Split AC device initialized successfully”))
end
end
end
end
end
end
  – Validate the mode
      return
    end
  end
end
      return
    end
  end
end
      return
    end
  end
end
  else
  end
end
end
    type = "LAN",
  if device then
  else
  end
end
    init = driver_init,
    [capabilities.switch.ID] = {
      [capabilities.switch.commands.on.NAME] = handle_switch_on,
      [capabilities.switch.commands.off.NAME] = handle_switch_off
    [capabilities.airConditionerMode.ID] = {
      [capabilities.airConditionerMode.commands.setAirConditionerMode.NAME] = handle_ac_mode_change
    [capabilities.airConditionerFanMode.ID] = {
      [capabilities.airConditionerFanMode.commands.setFanMode.NAME] = handle_fan_mode_change
    [capabilities.fanOscillationMode.ID] = {
      [capabilities.fanOscillationMode.commands.setFanOscillationMode.NAME] = handle_oscillation_mode_change
    [capabilities.thermostatCoolingSetpoint.ID] = {
      [capabilities.thermostatCoolingSetpoint.commands.setCoolingSetpoint.NAME] = handle_cooling_setpoint_change
    [capabilities.refresh.ID] = {
      [capabilities.refresh.commands.refresh.NAME] = handle_refresh
-- Run the driver
There’s an entire part missing where you actually talk to the device.
Correct me if I’m wrong, but these are directly connected devices—they communicate with the cloud, if I recall correctly.
If it were that simple, someone would have already written a driver.
I’m trying to create a virtual device of a Samsung mini split AC for testing a multi-device scenario.
You should have mentioned that from the start…
Kindly support me to fix it
There’s so much wrong with your code…
Why do you call the discovery function in the init lifecycle?
Why an extra function to initialize the device?
There’s a log.info(“…”))- double ))
This is how you usually, correctly set a cooling setpoint:
device:emit_event(capabilities.thermostatCoolingSetpoint.coolingSetpoint({ value = setpoint, unit = "F" }))
Why a lifecycle driverSwitched?
The driver log must be a mess…
How to fix this, I’m new to SmartThings Edge driver creation
check this out
– Author: Ashwin (fixed)
– Date: August 12, 2025
– Driver constants
local DEVICE_PROFILE = “samsung-mini-split” – must match your profile name in resources
– --------- helpers ---------
local function dev_tag(device)
– Safe tag for logs; Edge devices may not expose device_network_id
return string.format(“[%s | %s]”, device.label or “Device”, device.id or “no-id”)
end
local function temp_unit(device)
– Keep a single unit consistently; adjust if you add a preference later
return “F”
end
– Initialize device with default attribute values
log.info(string.format(“Initializing device %s”, dev_tag(device)))
device:emit_event(capabilities.temperatureMeasurement.temperature({ value = 77, unit = temp_unit(device) }))
– thermostatCoolingSetpoint (emit once, with unit)
device:emit_event(capabilities.thermostatCoolingSetpoint.coolingSetpoint({ value = 69, unit = temp_unit(device) }))
– switch
log.info(string.format(“Device initialized %s”, dev_tag(device)))
end
– Handle device added
log.info("Device added " .. dev_tag(device))
end
– Handle device initialization (also used after driver switch)
log.info("Device init " .. dev_tag(device))
end
– Handle switch on/off
log.info("Switch ON " .. dev_tag(device))
end
log.info("Switch OFF " .. dev_tag(device))
end
– AC mode change
local mode = command and command.args and command.args.mode
log.info(string.format(“Set AC mode → %s %s”, tostring(mode), dev_tag(device)))
local allowed = { auto=true, cool=true, dry=true, fan=true, heat=true }
if allowed[mode] then
else
log.warn("Unsupported AC mode: " .. tostring(mode))
end
end
– Fan mode change
local fm = command and command.args and command.args.fanMode
log.info(string.format(“Set Fan mode → %s %s”, tostring(fm), dev_tag(device)))
local allowed = { auto=true, low=true, medium=true, high=true, turbo=true }
if allowed[fm] then
device:emit_event(capabilities.airConditionerFanMode.fanMode(fm))
else
log.warn("Unsupported fan mode: " .. tostring(fm))
end
end
– Oscillation mode change
local om = command and command.args and command.args.fanOscillationMode
log.info(string.format(“Set Oscillation → %s %s”, tostring(om), dev_tag(device)))
local allowed = { fixed=true, vertical=true, horizontal=true, all=true }
if allowed[om] then
device:emit_event(capabilities.fanOscillationMode.fanOscillationMode(om))
else
log.warn("Unsupported oscillation mode: " .. tostring(om))
end
end
– Cooling setpoint change
log.info("=== COOLING SETPOINT HANDLER === " .. dev_tag(device))
local sp = nil
– Capability schema uses ‘setpoint’; some UIs send ‘value’
if command and command.args then
sp = command.args.setpoint or command.args.value
end
log.info("Requested setpoint: " .. tostring(sp))
– Validate range (61–86F). Adjust if you later add a preference.
if type(sp) == “number” and sp >= 61 and sp <= 86 then
device:emit_event(capabilities.thermostatCoolingSetpoint.coolingSetpoint({ value = sp, unit = temp_unit(device) }))
-- Optional: keep temperatureMeasurement loosely in sync to reflect changes
-- (remove this if your physical device reports actual room temp)
-- device:emit_event(capabilities.temperatureMeasurement.temperature({ value = sp, unit = temp_unit(device) }))
log.info("Cooling setpoint updated")
else
log.warn(“Setpoint out of range or invalid: " .. tostring(sp) .. " (valid 61–86°F)”)
end
end
– Refresh
log.info("Refresh requested " .. dev_tag(device))
end
– Discovery
log.info(“Starting discovery…”)
– If you already have a device, skip creating duplicates
local existing = false
for _, d in ipairs(driver:get_devices()) do
if d.device_network_id == “samsung-mini-split-001” or d.label == “Samsung Mini Split AC” then
existing = true
break
end
end
if existing then
log.info(“Device already exists; skipping creation”)
return
end
local metadata = {
type = “LAN”,
device_network_id = “samsung-mini-split-001”,
label = “Samsung Mini Split AC”,
manufacturer = “Samsung”,
model = “Mini Split AC”,
vendor_provided_label = “Samsung Mini Split Air Conditioner”,
local ok, err = pcall(function() driver:try_create_device(metadata) end)
if ok then
log.info(“Device created”)
else
log.error("Device creation failed: " .. tostring(err))
end
end
– Driver init (do NOT force discovery here; the framework will call discovery)
log.info(“- Switch capability: " .. tostring(capabilities.switch.ID))
log.info(”- AC Mode capability: " .. tostring(capabilities.airConditionerMode.ID))
end
– Build the driver
init = driver_init,
driverSwitched = device_init, – re-init after migration
[capabilities.switch.commands.off.NAME] = handle_switch_off,
[capabilities.airConditionerMode.commands.setAirConditionerMode.NAME] = handle_ac_mode_change,
[capabilities.airConditionerFanMode.commands.setFanMode.NAME] = handle_fan_mode_change,
[capabilities.fanOscillationMode.commands.setFanOscillationMode.NAME] = handle_oscillation_mode_change,
[capabilities.thermostatCoolingSetpoint.commands.setCoolingSetpoint.NAME] = handle_cooling_setpoint_change,
[capabilities.refresh.commands.refresh.NAME] = handle_refresh,
– Run the driver
Nope, I’m not doing a code review until it runs properly. Your turn to work on it again for a few hours.
Your whole code looks like it’s AI generated…
Hi, @Ashwin
You should start with a basic structure that works. This is a sample of a switch, it’s a LAN driver but in the end, it’s an instance simulating a switch.
There, you would need to add the corresponding capabilities to the profile and then, initialize them accordingly.
If you don’t see changes in the app after you modified something in the profile, we suggest you change the network ID and device label to force an update.
Generally, adding new capabilities will force an update for the device presentation, but just in case.
Remember the networkID must be unique, so, if the device isn’t discovered, check first that the networkID doesn’t exist yet for another device.
Thank you, it will be very useful
@Andreas_Roedl @nayelyz Created virtual AC
with my driver alone the provision state is also changes to TYPED
but same issue Unable to set temperature and cooling setpoint , commands are getting accepted through CLI , but for temperature it shows no command
local cosock = require “cosock”
local socket = require “cosock.socket” – sleep + time
-- RNG seed for unique DNIs (time-based + random)
do
local seed = math.floor((socket.gettime() or os.time()) * 1e6) % 0x7fffffff
math.randomseed(seed)
end
-- ---------- helpers ----------
local dni_counter = 0 – static counter to ensure uniqueness
local function new_dni()
dni_counter = dni_counter + 1
local timestamp = socket.gettime() or os.time() – microsecond precision if available
local ms = math.floor((timestamp * 1000) % 1000) – extract milliseconds
return string.format(“mini-split-%d-%03d-%04d”,
math.floor(timestamp), ms, dni_counter % 10000)
end
-- ---------- default attributes ----------
device:emit_event(capabilities.thermostatCoolingSetpoint.coolingSetpoint({ value = 69, unit = “F” }))
device:emit_event(capabilities.temperatureMeasurement.temperature({ value = 77, unit = “F” }))
end
-- ---------- lifecycle (per-device) ----------
log.info(“[” .. device.id .. “] Adding new Samsung Mini Split device”)
end
log.info(“[” .. device.id .. “] Initializing Samsung Mini Split device”)
device:online() – mark device as online like the official example
end
-- ---------- commands ----------
local function handle_switch_on (driver, device, cmd) device:emit_event(capabilities.switch.switch(“on”)) end
local function handle_switch_off(driver, device, cmd) device:emit_event(capabilities.switch.switch(“off”)) end
local function handle_set_cooling(driver, device, cmd)
local sp = tonumber(cmd.args.setpoint or cmd.args.value)
if sp and sp >= 61 and sp <= 86 then
device:emit_event(capabilities.thermostatCoolingSetpoint.coolingSetpoint({ value = sp, unit = "F" }))
else
log.warn("Cooling setpoint out of range: " .. tostring(sp))
end
end
-- ---------- discovery (for Scan Nearby) ----------
-- handle discovery events, normally you’d try to discover devices on your
-- network in a loop until calling `should_continue()` returns false.
local function discovery_handler(driver, _should_continue)
log.info(“Starting Samsung Mini Split Discovery”)
– Check if we already have a Samsung Mini Split device
for _, device in ipairs(driver:get_devices()) do
if device.profile and device.profile.name == "samsung-mini-split" then
  log.info("Samsung Mini Split device already exists: " .. device.device_network_id)
  return  -- Don't create duplicate
end
end
local dni = new_dni()
log.info("Creating device with unique DNI: " .. dni)
local metadata = {
type = "LAN",
-- the DNI must be unique across your hub, using dynamic ID here
device_network_id = dni,
profile = "samsung-mini-split",
model = "Mini Split",
vendor_provided_label = nil
– tell the cloud to create a new device record, will get synced back down
– and `device_added` and `device_init` callbacks will be called
log.info("Device creation requested with DNI: " .. dni)
end
-- ---------- driver object ----------
local driver = Driver(“SamsungMiniSplitDriver”, {
init = device_init,
  \[capabilities.thermostatCoolingSetpoint.commands.setCoolingSetpoint.NAME\] = handle_set_cooling
-- run the driver
log.info(“DRIVER: Starting Samsung Mini Split driver”)
driver:run()
Hi, @Ashwin
Is it possible for you to upload your code to a Github repository and share it with me? If it has sensitive information, you can share it only with my user nayelyzarazua-bluetrail
I want to use your exact configuration to check on my side what might be incorrect.
Also, something important is checking the driver logs to see if there’s an error message shown.
Are you listening for the driver logs with the command below?
smartthings edge:drivers:logcat
will share shortly, I’m not seeing it because I’m accessing the from remote.
HUB is on different network , so i can’t see smartthings edge:drivers:logcat
@nayelyz
shared repo
What do you mean?
I see…
It’s absolutely impossible to develop a driver without access to the driver logs.
Everything I mentioned above would show up in the logs. Your driver wouldn’t even run in this state.
Is it a remote job, a personal project or what?
