Hi,
I have recently purchased a Hank One-key scene controller that I have some difficulty getting to work.
http://www.hank-tech.com/product-detail.aspx?id=343&pid=1#product_cont
I have successfully connected it to the Smartthings hub and it shows up as a Z-wave device. I have also no problem adding the One-key to a room or otherwise handle it in the Smartthings hub.
But when I try to set it up to turn off and turn on lights and powerplugs I can’t get that to work.
I use the Smartapp “Smart lighting” and configure it as in the included link below.
https://photos.app.goo.gl/buvEY12MDHGnMEt13
There is no way to select button in “select trigger” only switch.
Where “PC” is a Fibaro powerplug and “Lightstrip” is a Philips Hue lightstrip” and the “Computer button” is the Hank One-Key scenen controller.
I have no problem controlling these two lights with voice (Google home) routines/scenes or separately within the Smartthings android app.
What am I doing wrong?
Is the Hank one-key scene controller able to control lights in Smartthings?
I have paired it as a non secure device and I have done the “testing z-wave network range” test with good results (solid green light)
Manual for the controller is here:
Have anyone any experience using the Hank one-key scene controller?
Appreciate any help in this matter,
//Peter
