GE Z-wave add-on switch wiring
Yes indeed thats the black screw
OK, that black wire is your load wire. You should be able to tell by looking at the romex and it should be a 14/2.
The 14/3 red, black and white is the one going back to your master switch and the red and black of this romex connected to the 2 gold or white terminals of the aux switch correct?
Thanks for all the input I haven’t gone back at it yet, I’m waiting on some items to be delivered before I go back into the wiring… a GE keypad controller and a set of linear 3 ways which are wireless and don’t require the traveler.
Just want to have options in case I can’t get the wiring without going into the very tight and high attic.
what model is the keypad controller? if its the one i’m thinking of, it doesn’t work with smartthings as a button controller.
This one…
GE 45631 Z-Wave Wireless Keypad Controller https://www.amazon.com/dp/B003OUWABU/ref=cm_sw_r_cp_api_6pwLyb6EFBS8B
yeah. Not sure how you intend to use it, but it doesn’t work as a button controller like a minimote does when you can takes action in SmartThings based on X button being pressed. it’s a secondary controller that you can use to directly control devices.
Ah that’s lame!
So I followed the instructions in the package and had no problem assigning my Lights to the up / down arrows, which act just like a dimmer switch.
I’m very pleased with this device since it can do 4 different switches or groups, and potentially other functions. And it can be mounted on the walls with a command strip to look just like a gang switch!
