I have a GE Dimmer that I tried to use with Double Tap to no avail yesterday. This morning I took a look at the code and simulated it in the IDE and found the issue. Some devices, including the virtual device you are given to test with, do not send an event if the event is not changing the device state. So, for example, when I double-tap my switch the first tap turns it on and is sent as an event. The second tap the switch is already on therefore it is not sent as an event. I can rewrite a version of Double Tap that works by flicking the switch on/off (and I did for testing purposes and it worked fine) or vice-versa, but that’s not ideal.
I do believe there is a way to create a device type that will send an event regardless of its affect on the device state, but I could not find a way to use such a device in the IDE for testing. I am brand new at working with ST development, so does anyone with more experience know how I can go about fixing this issue? Is there a way to use custom device types in the SmartApps simulation?
