I have a broken hue bulb. the diffuser is cracked on one side and i have a jagged 1x1 inch square that is missing. looks like I can use a 3d printer to replace/repair the diffuser but i wanted to see if anyone had other idea first. the bulb still works but pretty useless with broken diffuser
PHILIPS HUE White & Color Ambiance A19 Single Bulb
really hard to explain how it looks but its like you can see the individual led lights reflecting . when its set to soft white it still shows blue and other colors shining out… but if i lay a translucent piece of plastic over it then it looks like it should. it gets pretty warm so i was tossing ideas around and i thought someone here may have already been through the trial and error of fixing one. the bulb is 50 bucks normally so if i can fix for 2 bucks I’m going to fix it
