FAQ: Neutral and Ground Wires are not Interchangeable
Don’t want to turn this thread into something else but I highly doubt it any decent electrician would say it’s ok even off the record. A ground is not a neutral period. The last thing you want is the chassis of your washer as a current carrying conductor. If your house has a bonded neutral and ground then it should be at only at one connector and that is your circuit breaker panel and nowhere else. This is actually a huge safety issue.
