Hello, I’m just putting this out here for the community.
It combines several of the Samsung Community GitHub examples with some Rules API info from the community and puts together a functional SmartApp, typed pretty completely with TypeScript.
I set aside a static branch here, while the ‘main’ branch will be my continued development of a much more complicated multi-smartapp environment (so be sure to follow that link above to the specific branch for the isolated example).
I also tried to be very explicit, with screenshots and steps in setup and configuration.
I was satisfied enough with the current state to think it may provide some good example data for others.
Hope it helps someone. I don’t have intentions to make continued updates and formal ‘RELEASE’, but people are welcome to fork and clone.
As a short summary…
After selecting a motion sensor, some sets of switches (lights) in your home and some time ranges, it…
- sets up a rule to run during configured daylight hours based on motion of the sensor(s) detected
- sets up a rule to run during configured nighttime hours based on motion of the sensor(s) detected
- sets up an ‘idle’ rule to turn off the selected device(s) after an amount of idle time
- sets up a ‘transition’ rule to change day–>night if devices are active
- allows configuration of delays, customized time ranges, disabling of specific rules and describes the configured rules current configuration on open of the smart-app
By installing multiple of these ‘SmartApps’ in your home you can configure several rooms/areas independently. To be fair, it’s also what met my needs…
