I wanted to automate the lighting in my bathrooms so that the lights would turn on when the door was opened, and turn off when the door was opened a second time, but couldn’t find a way to do this with Smart Lighting. I tried a CoRE piston, but it was a little too slow. So I decided to write a simple smart app!
Note that this also handles the use cases where:
- the user opens the door, pokes their head in, and turns off the light manually and closes the door
- the user opens the door, enters the room, closes the door, turns off the light manually while inside, and opens the door again
- the user opens the door, enters the room, closes the door, then opens the door again while turning the light off manually.
I can’t think of any other use cases, but let me know if there are any!
* Copyright 2016 Zach Spencer
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Enhanced Toggle It When It Opens
* Author: Zach Spencer
definition(
name: "Enhanced Toggle It When It Opens",
namespace: "zcspencer",
author: "Zach Spencer",
description: "Toggle something when an open/close sensor opens.",
category: "Convenience",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Meta/light_contact-outlet.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Meta/light_contact-outlet@2x.png"
preferences {
section("When the door opens..."){
input "contact1", "capability.contactSensor", title: "Where?"
section("Toggle a light..."){
input "switches", "capability.switch", multiple: false
def installed()
subscribe(contact1, "contact.open", contactOpenHandler)
subscribe(switches, "switch", switchHandler)
def updated()
unsubscribe()
def switchHandler(evt) {
// if the switch was turned off by the user and the contact is closed then don't automatically
// turn off switch next time contact is opened
state.lastSwitchPhysical=(evt.physical && evt.value == "off" && contact1.currentContact == "closed")
def contactOpenHandler(evt) {
log.debug "$evt.value: $evt, $settings"
if (switches.currentSwitch == "off") {
if (!state.lastSwitchPhysical) {
log.trace "Turning on switch: $switches"
switches.on()
} else {
log.trace "User turned off switch manually, skipping turning on $switches"
state.lastSwitchPhysical=false
} else {
log.trace "Turning off switch: $switches"
switches.off()
