The only thing that creates some problems is the dynamic change of the icon, in the sense that sometimes it goes back to the old profile then changes again.
Also you should edit the profiles within the âZigbee Light Multifunction Mcâ driver for these devices that I have and they work fine
ST motion and plug are still pairing with stock dth.
Ecolink pairs and works with exception of battery data.
TS0001 paired as a âthingâ as it did originally and has to change to ZigBee switch in IDE and did work as intended on the stock dth.
MmmâŠI havenât seen comments about issues pairing Sonoff devices from other devs, but it could be the case for the _TX3000_hktqahrq manufacturer
But @Paul_Oliver, please verify the fingerprint values of both devices in the Hub events when the device is paired.
Got to the IDE and select âMy Hubsâ
Tap on âList Eventsâ (it is the penultimate option in the table)
The paint event is before the âdeviceAddâ event. Eg.
@nayelyz,
I do not quite understand what is happening so there are more problems to match the drives when the devices have full or generic fingerprints in DTH Stokcs.
The ST motion sensor motionv5 is in the dth stock smartsense motion sensor
Yes, thatâs correct, but if theyâre paired to stock DTHs, it means the matching fingerprint is not found in any driver installed. Letâs review the things we need to check:
The fingerprint must match the one in the deviceâs DTH, if thereâs no DTH, then you need to look at the Hub events (instructions here).
The driver must be assigned again to the channel when itâs updated (package and publish). Remember that for the users invited, updates might take a few hours to be effective.
If you add more fingerprints to your driver, and only some of them are failing, then the device has a specific issue
If all new fingerprints are not working (even after the automatic update), then, something might be wrong with the driverâs update.
I just got the Sonoff Mini to pare as a driver using the âZigBee Switch mcâ driver, but it is not functioning.
The app shows it stuck in the ON position, but the light connected to it is off.
If I operate the dumb switch connected to the Sonoff Mini the light goes on and off and the app shows the correct status. After the manual switch operation the app can be used for a few cycles before it gets stuck in the ON position with the light off. In addition the icon does not change.
If tried uninstalling and reparing the mini, rebooting the hub, closing the app, clearing the cache, force stopping the app. I did each of the above multiple times and nothing helps.
I also tried to operate it via an Automation and that did not work.
The only thing that works is cycling the dumb switch, but that only fixes the app for 1 to 3 cycles.
EDIT: After several hours the icon changed to a bulb, but the switch still can NOT be operated from the app or automations.
The Tuya TZ3000 switch pared as a driver on the 1st try using the âZigBee Switch mcâ driver. I was able to change the icon and it works as expected.
I think this is very important to keep in mind for users who are already using a driver and have requested or want to use other devices added later to that driver.
Once published, they have to wait for the automatic driver update for several hours.
If you want it to be faster, you should uninstall the hub driver and reinstall the new version.
This implies not having devices paired to the driver to uninstall it.
You can check the version of the driver (Date and time of creation of the driver) in details of the hub, menu driver, select a driver
