Would it be possible to add more settings for the Dimmer 2 (FGD-212)? For the longest time I’ve been using codersaur’s custom DTH that allowed setting the default switch on brightness level (ConfigParam19) and also the NIGHTMODE options which allowed you to set a lower switch on brightness level between specific times. As I understood from the DTH, it stored the previous value of ConfigParam19 in cache then set it to the new lower value until the end time happened before switching it back. This old DTH doesn’t work too well with the more recent versions of ST so I’ve been looking for an alternative way of doing this. I’ve found this driver to react much faster than the DTH so would love to see these couple of options added too.
Roller Shutter 3 (FGR-223)
I have a problem, even if the wires are connected correctly, I have to reverse the setting q1 and q2, after doing it, they work but I have to reverse s1 and s2 which start to go backwards.
power consumption is not recorded but is the least.
the real problem is that I have to click on alt many times before cghe stops, and often while I do it is enchanted and I have to restart the application! what could it be?
I don’t have the device and I don’t know very well how it works, I only added it to the driver for users who requested and tried it.
I know that physical switches can be inverted in preferences.
The one that doesn’t respond quickly seems like a zwave network problem.
When re-pairing with edge the device may not have the best route and need to do a zwave repair.
Anyway I have noticed that my zwave network works much slower than zigbee since a few weeks and there is no way to fix or improve it, I have given up!
Maybe a user who has the device in use can help you better.
Hi @Mariano_Colmenarejo , I have just paired a Fibaro Roller Shutter 3 and it paired it with the “Z-wave switch Mc” driver even if I installed the “Z-Wave Window Treatment Mc” driver. Do you have an idea why and how to fix it?
Right, I didn’t specified, it doesn’t show me another driver to choose in the app. Is it possible I have to wait a bit? The hub is fresh out of the box and I’m installing lot of stuff on it.
Also, is this fingerprint covered? I thought maybe they have several fingerprints for the same model…
The driver is correctly installed because I have 5 Fibaro RS 2 that paired with it immediately.
I removed it and repaired with the hub, now it has the right driver. No idea why this fixed it, but anyway… Thanks for the availability and sorry for having bothered you!
This isn’t a Fibaro request, but since the code seems to be similar between them and Zooz, do you think you could add the ZEN15 power metering switch to your stable of drivers.
I’m running them on the smartthings stock driver with no custom capabilities. One is on refrigerator and other whole house dehumidifier.
fingerprint mfr:“027A”, prod:“0101”, model:“000D”, deviceJoinName: “Zooz Power Switch” // VER 1.0 & 2.0
I’m in the Zooz beta and doesn’t seem very promising for older devices as of now. Was a long shot asking you, but I know you did the ZEN31, so figured I’d give you a try.
The Edge driver is working for the first 2 devices but not the third. I wonder what kind of issue would make the Edge driver stop working on the third, but work correctly on the first two? Have tried clearing app cache? Restarting app and hub? Deleting device from hub, factory resetting it, then including it again? Many things to try first.
