@blueyetisoftware I think there is only some sort of restriction that iquix is doing because he copied code from someone else. It probably won’t be too hard to redo and make open source. I wish I knew enough to make the modification because I would have like to simplify the info displayed on the tile. It seems there was some work around or something needed to connect to the device but once you do it will just return this string and you just assign the data for each sensor/capability. And not sure if there is access to the smartthings air care. The old official integration was able to but I guess people cant make their own devices work with it?
example of data
“{“timestamp”:“2022-08-29T01:47:18.254Z”,“score”:92,“dew_point”:14.36,“temp”:24.18,“humid”:54.28,“abs_humid”:11.90,“co2”:453,“co2_est”:465,“co2_est_baseline”:35883,“voc”:460,“voc_baseline”:38401,“voc_h2_raw”:25,“voc_ethanol_raw”:36,“pm25”:0,“pm10_est”:1}”
