@yvesracine, live logging shows the disarm command is being sent instead of armAway or armStay. I think the current state may not be showing correctly so it’s sending the wrong command. I am completely new to coding and have copied the device type below. Do you have any suggestions?
- SecurityAlarmPanel
- Author: ObyCode
- based on work by Josh Foshee
- Modified by Yves Racine to include system statuses
- Date: 2014-06-10https://graph.api.smartthings.com/ide/devices
metadata {
// Automatically generated. Make future change here.
definition (name: “SecurityAlarmPanel”, author: "brice@obycode.com") {
capability "Alarm"
capability "Switch"
capability "Motion Sensor"
capability "Contact Sensor"
capability “Refresh”
attribute "alarmStatus", "string"
attribute "entranceDoor", "string"
attribute "garageSideDoor", "string"
attribute "familyWindows", "string"
attribute "patioDoor", "string"
attribute "diningWindows", "string"
attribute "frontMotion", "string"
attribute "switchAway", "string"
attribute "switchStay", "string"
attribute "panic", "string"
attribute "systemStatus", "string"
attribute "response", "string"
command "armAway"
command "armStay"
command "disarm"
command "clear"
command "update"
command "chimeToggle"
command "panic"
command "away"
// Simulator metadata
simulator {
// status messages
status "ping": "catchall: 0104 0000 01 01 0040 00 6A67 00 00 0000 0A 00 0A70696E67"
status "hello": "catchall: 0104 0000 01 01 0040 00 0A21 00 00 0000 0A 00 0A48656c6c6f20576f726c6421"
// UI tile definitions
tiles {
standardTile("alarmStatus", "device.alarmStatus", width: 2, height: 2, canChangeIcon: false, canChangeBackground: false) {
state "ready", label: 'Ready', action: "armStay", icon: "st.Home.home2", backgroundColor: "#ffffff"
state "disarmed", label: 'Ready', action: "armAway", icon: "st.Home.home2", backgroundColor: "#ffffff"
state "notready", label: 'Not Ready', icon: "st.Home.home2", backgroundColor: "#ffa81e"
state "away", label: 'Away', action: "disarm", icon: "st.Home.home3", backgroundColor: "#add8e6"
state "stay", label: 'Stay', action: "disarm", icon: "st.Home.home4", backgroundColor: "#f1d801"
state "arming", label: 'Arming', action: "disarm", icon: "st.Home.home2", backgroundColor: "#B8B8B8"
state "alarm", label: 'Alarm', action: "clear", icon: "st.Home.home2", backgroundColor: "#ff0000"
standardTile("away", "device.awaySwitch", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false) {
state "on", label: "Away", action: "disarm", icon: "st.Home.home3", backgroundColor: "#add8e6"
state "off", label: "Away", action: "armAway",icon: "st.Home.home3", backgroundColor: "#ffffff"
standardTile("stay", "device.staySwitch", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false) {
state "on", label: "Stay", action: "disarm", icon: "st.Home.home4", backgroundColor: "#f1d801"
state "off", label: "Stay", action: "armStay",icon: "st.Home.home4", backgroundColor: "#ffffff"
// For the moment, each sensor has its own states due to a smartthings UI framework issue on android.
// To be fixed later: states should be 'open', 'closed', 'active', 'inactive'
standardTile("entranceDoor", "device.entranceDoor",width: 1, height: 1, canChangeIcon: false, canChangeBackground: true) {
state "ED open", label:'entrance\nDoor', icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
state "ED closed", label:'entrance\nDoor', icon: "st.contact.contact.closed", backgroundColor: "#79b821"
standardTile("garageSideDoor", "device.garageSideDoor", width: 1, height: 1,inactiveLabel: false, canChangeIcon: true, canChangeBackground: true) {
state "GSD open", label:'garage\nSide Door', icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
state "GSD closed", label:'garage\nSide Door', icon: "st.contact.contact.closed", backgroundColor: "#79b821"
standardTile("familyWindows", "device.familyWindows", width: 1, height: 1,inactiveLabel: false, canChangeIcon: true, canChangeBackground: true) {
state "FW open", label:'family\nFamily Window', icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
state "FW closed", label:'family\nFamily Window', icon: "st.contact.contact.closed", backgroundColor: "#79b821"
standardTile("patioDoor", "device.patioDoor", width: 1, height: 1,inactiveLabel: false,canChangeIcon:true, canChangeBackground: true) {
state "PD open", label:'patio\nDoor', icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
state "PD closed", label:'patio\nDoor', icon: "st.contact.contact.closed", backgroundColor: "#79b821"
standardTile("diningWindows", "device.diningWindows", width: 1, height: 1,inactiveLabel: false, canChangeIcon: true, canChangeBackground: true) {
state "DW open", label:'dining\nDining Window', icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
state "DW closed", label:'dining\nDining Window', icon: "st.contact.contact.closed", backgroundColor: "#79b821"
standardTile("frontMotion", "device.frontMotion", width: 1, height: 1, inactiveLabel: false,canChangeIcon:true, canChangeBackground: true) {
state "FM active", label:'motion\nMotion', icon: "st.motion.motion.active", backgroundColor: "#ffa81e"
state "FM inactive", label:'motion\nMotion', icon: "st.motion.motion.inactive", backgroundColor: "#79b821"
standardTile("chime", "device.chime", width:1, height: 1, canChangeIcon: false, canChangeBackground: false) {
state "chimeOff", label:'Chime', action:'chimeToggle', icon:"st.secondary.off", backgroundColor: "#ffffff"
state "chimeOn", label:'', action:'chimeToggle', icon:"st.secondary.beep", backgroundColor: "#ffffff"
standardTile("panic", "device.panic", width: 1, height: 1, canChangeIcon: false, canChangeBackground: true) {
state "panic", label:'Panic', action:"panic", icon:"st.alarm.alarm.alarm", backgroundColor:"#ff0000"
valueTile("systemStatus", "device.systemStatus", inactiveLabel: false,
decoration: "flat", width: 3, height: 1) {
state "default", label: '${currentValue}'
standardTile("refresh", "device.refresh", inactiveLabel: false, width: 1, height: 1, canChangeIcon: false, canChangeBackground: false) {
state "default", action:"refresh", icon:"st.secondary.refresh"
main(["alarmStatus"])
details(["alarmStatus","away","stay","entranceDoor","garageSideDoor","familyWindows","patioDoor","diningWindows","frontMotion","chime","systemStatus","refresh","panic"])
// Parse incoming device messages to generate events
log.debug description
def stateToDisplay
def msg = zigbee.parse(description)?.text
log.debug "Received ${msg}"
def result
if (!msg || msg.trim() == "ping") {
result = createEvent(name: null, value: msg)
// update()
} else if ( msg.length() >= 4 ) {
if ( msg.substring(0, 2) == “RD” ) {
if (msg[3] == “0”) {
result = createEvent(name: “alarmStatus”, value: “notready”)
// When status is “Not Ready” we cannot arm
//createEvent(name: “away”, value: “off”)
//createEvent(name: “stay”, value: “off”)
sendEvent(name: “switchAway”, value: “off”)
sendEvent(name: “switchStay”, value: “off”)
sendEvent(name: “contact”, value: “open”)
sendEvent(name: “response”, value: “alarmStatus notready”, type: alarmStatus)
else {
result = createEvent(name: "alarmStatus", value: "ready")
// When status is "Ready" we can arm
//createEvent(name: "away", value: "on")
//createEvent(name: "stay", value: "on")
sendEvent(name: "switchAway", value: "on")
sendEvent(name: "switchStay", value: "on")
sendEvent(name: "switch", value: "off")
sendEvent(name: "panic", value: "off")
sendEvent(name: "contact", value: "open")
sendEvent(name: "systemStatus", value: "System Status:No events")
sendEvent(name: "response", value: "alarmStatus ready", type: alarmStatus)
// Process arm update
} else if ( msg.substring(0, 2) == "AR" ) {
if (msg[3] == "0") {
result = createEvent(name: "alarmStatus", value: "disarmed")
sendEvent(name: "response", value: "alarmStatus disarmed", type: alarmStatus)
else if (msg[3] == "1") {
if (msg[4] == "0" | msg[4] == "2") {
result = createEvent(name: "alarmStatus", value: "away")
sendEvent(name: "switch", value: "on")
sendEvent(name: "contact", value: "closed")
sendEvent(name: "response", value: "alarmStatus away", type: alarmStatus)
else if (msg[4] == "1" | msg[4] == "3") {
result = createEvent(name: "alarmStatus", value: "stay")
sendEvent(name: "response", value: "alarmStatus stay", type: alarmStatus)
else if (msg[3] == "2") {
result = createEvent(name: "alarmStatus", value: "arming")
sendEvent(name: "response", value: "alarmStatus arming", type: alarmStatus)
} else if ( msg.substring(0, 2) == "SY" ) {
// Process various system statuses
if ( msg.substring(3, 3) == "658") {
result = createEvent(name: "systemStatus", value: "System Status\nKeypad Lockout")
else if ( msg.substring(3, 3) == "670") {
result = createEvent(name: "systemStatus", value: "System Status\nInvalid Access Code")
else if ( msg.substring(3, 3) == "672") {
result = createEvent(name: "systemStatus", value: "System Status\nFailed to arm")
else if ( msg.substring(3, 3) == "802") {
result = createEvent(name: "systemStatus", value: "System Status\nPanel AC Trouble")
else if ( msg.substring(3, 3) == "803") {
result = createEvent(name: "systemStatus", value: "System Status\nPanel AC Trouble Rest")
else if ( msg.substring(3, 3) == "806") {
result = createEvent(name: "systemStatus", value: "System Status\nSystem Bell Trouble")
else if ( msg.substring(3, 3) == "807") {
result = createEvent(name: "systemStatus", value: "System Status\nSystem Bell Trouble Rest")
else if ( msg.substring(3, 3) == "810") {
result = createEvent(name: "systemStatus", value: "System Status\nTLM line 1 Trouble")
else if ( msg.substring(3, 3) == "811") {
result = createEvent(name: "systemStatus", value: "System Status\nTLM line 1 Trouble Rest")
else if ( msg.substring(3, 3) == "812") {
result = createEvent(name: "systemStatus", value: "System Status\nTLM line 2 Trouble")
else if ( msg.substring(3, 3) == "813") {
result = createEvent(name: "systemStatus", value: "System Status\nTLM line 2 Trouble Rest")
else if ( msg.substring(3, 3) == "821") {
result = createEvent(name: "systemStatus", value: "System Status\nLow Battery at " + substring(6,3))
else if ( msg.substring(3, 3) == "822") {
result = createEvent(name: "systemStatus", value: "System Status\nLow Battery Rest at " + substring(6,3))
else if ( msg.substring(3, 3) == "829") {
result = createEvent(name: "systemStatus", value: "System Status\nSystem Tamper")
else if ( msg.substring(3, 3) == "830") {
result = createEvent(name: "systemStatus", value: "System Status\nSystem Tamper Rest")
else if ( msg.substring(3, 3) == "840") {
result = createEvent(name: "systemStatus", value: "System Status\nTrouble Status(LCD)")
else if ( msg.substring(3, 3) == "841") {
result = createEvent(name: "systemStatus", value: "System Status\nTrouble Status Rest")
else if ( msg.substring(3, 3) == "896") {
result = createEvent(name: "systemStatus", value: "System Status\nKeybus fault")
else if ( msg.substring(3, 3) == "897") {
result = createEvent(name: "systemStatus", value: "System Status\nKeybus Fault Rest")
// Process alarm update
} else if ( msg.substring(0, 2) == "AL" ) {
result = createEvent(name: "alarmStatus", value: "alarm")
sendEvent(name: "response", value: "alarmStatus alarm", type: alarmStatus)
// Process chime update
} else if ( msg.substring(0, 2) == "CH" ) {
result = createEvent(name: "chime", value: "chimeOn")
} else {
result = createEvent(name: "chime", value: "chimeOff")
// Process zone update
} else if ( msg.substring(0, 2) == "ZN" ) {
if ( msg.substring(3, 9) == "609001" ){
stateToDisplay = "ED open"
result = createEvent(name: "entranceDoor", value: stateToDisplay)
sendEvent(name: "response", value: "r 1 open", type: "Open/Closed Sensor")
else if ( msg.substring(3, 9) == "610001" ){
stateToDisplay = "ED closed"
sendEvent(name: "response", value: "r 1 closed", type: "Open/Closed Sensor")
else if ( msg.substring(3, 9) == "609002" ){
stateToDisplay = "GSD open"
result = createEvent(name: "garageSideDoor", value: stateToDisplay)
sendEvent(name: "response", value: "r 2 open", type: "Open/Closed Sensor")
else if ( msg.substring(3, 9) == "610002" ){
stateToDisplay = "GSD closed"
sendEvent(name: "response", value: "r 2 closed", type: "Open/Closed Sensor")
else if ( msg.substring(3, 9) == "609003" ){
stateToDisplay = "FW open"
result = createEvent(name: "familyWindows", value: stateToDisplay)
sendEvent(name: "response", value: "r 3 open", type: "Open/Closed Sensor")
else if ( msg.substring(3, 9) == "610003" ){
stateToDisplay = "FW closed"
sendEvent(name: "response", value: "r 3 closed", type: "Open/Closed Sensor")
else if ( msg.substring(3, 9) == "609004" ){
stateToDisplay = "PD open"
result = createEvent(name: "patioDoor", value: stateToDisplay)
sendEvent(name: "response", value: "r 4 open", type: "Open/Closed Sensor")
else if ( msg.substring(3, 9) == "610004" ){
stateToDisplay = "PD closed"
sendEvent(name: "response", value: "r 4 closed", type: "Open/Closed Sensor")
else if ( msg.substring(3, 9) == "609005" ){
stateToDisplay = "DW open"
result = createEvent(name: "diningWindows", value: stateToDisplay)
sendEvent(name: "response", value: "r 5 open", type: "Open/Closed Sensor")
else if ( msg.substring(3, 9) == "610005" ){
stateToDisplay = "DW closed"
sendEvent(name: "response", value: "r 5 closed", type: "Open/Closed Sensor")
else if ( msg.substring(3, 9) == "609006" ){
stateToDisplay = "FM active"
result = createEvent(name: "frontMotion", value: stateToDisplay)
sendEvent(name: "motion", value: "active")
sendEvent(name: "response", value: "r 6 active", type: "Motion Detector")
else if ( msg.substring(3, 9) == "610006" ){
stateToDisplay = "FM inactive"
sendEvent(name: "response", value: "r 6 inactive", type: "Motion Detector")
else {
log.debug "Unhandled zone: " + msg
log.debug "Parse returned ${result?.descriptionText}"
return result
// Implement “switch” (turn alarm on/off)
def on() {
armStay()
def off() {
disarm()
def away() {
armAway()
// Commands sent to the device
def armAway() {
log.debug "Sending arm command"
zigbee.smartShield(text: “armAway”).format()
def armStay() {
zigbee.smartShield(text: “armStay”).format()
def disarm() {
log.debug "Sending disarm command"
zigbee.smartShield(text: “disarm”).format()
def strobe() {
panic()
def siren() {
panic()
def both() {
panic()
def chimeToggle() {
log.debug "Toggling chime"
zigbee.smartShield(text: “chimeOn”).format()
def panic() {
log.debug "Sending panic command"
zigbee.smartShield(text: “panic”).format()
// TODO: Need to send off, on, off with a few secs in between to stop and clear the alarm
def clear() {
disarm()
def refresh() {
update()
def update() {
log.debug "Sending update command"
zigbee.smartShield(text: “update”).format()
def configure() {
update()
