Hi. New to all this so just looking for a couple of pointers to see if something is even possible.
Can you have a device type. Not sure what. That can display dynmic text. For example read a state/text of something or be passed a value and display that.
For example a switch but shows a state as in off. On. Standby or a value of high medium low. But these would need to change. So could be either cat dog rabbit or one day say cow.
Short answer is no. Long answer is you can get a result that is similar to what you want by having multiple different states for the tile, each state being the option that you want to display.
Yeah wasn’t the best explanation. Basically would need a number of say buttons within the device that sends a value of say 1 2 or 3 depending on what’s pressed. But these are what I would like to be dynamic. I’m rubbish at explaining things!!! I ideally need to read something in from a device ie 1 2 or 3 but could be 4. Then show the value in the tile. Then ideally say these values somewhere then allow me to recall the value at any time to send back?!?!?!
i have a app running on my raspberry Pi that looks at the state of my ps4. it then returns a value of either On, Off, Standby or playing a game. so that’s why i need the status of the switch kind of thing. it would only ever need to return 2 states thou either on on or off. i could then use the raspberry to do what’s needed.
If state was standby send the on command for example
if it was on or playing a game then send the off command. if it was off then there is nothing that can be done as the app cant awake the ps4 from fully off.
then what i would like ie either a text field showing what game is playing as i can then supply that to the app/tile.
ideally what would also be good but i’m guessing this is way out is some kind of list/table i could populate with game names and that would allow me to select a name and start that from a tile/list/what ever.
i did this on the PI using node red as it just looked at the names of the games and created a list and then i had a drop down field to select. i did steal the code and modified it slightly so not 100% sure how it worked but was quite handy.
Yeah was having a look at the hungry state you posted. With a little work etc looks like it could work great for the status. Just need on and off button added in and then. The title played which you said was a valuetile. So I’ll have a look into that.
It seems your use case is basically what the player tile is doing but adapted to your raspberry information, Have a look at how this tile displays the song’s title at this link.
