sbs219
February 29, 2016, 2:47am
1
Is there a way to tell what or who is turning on and off lights with smartthings? Having an issue where lights are turning off by themselves, but it’s only my phone and my wifes phone that are added on the account. It just started about 10 minutes ago, and won’t stop unless I unplug the hub.
sidjohn1
(sidjohn1)
February 29, 2016, 11:18pm
2
This is a great place to start.
Logs and SmartThings:
https://graph.api.smartthings.com : This is the first place to go when SmartThings are not acting right. This is also the developer site, even if you’re not geek this is an excellent resource to check logs and forcibly delete smart apps and devices.
Live Logging:
https://graph.api.smartthings.com > Live Logging
This is where real time logs can be found. If you are having problems paring new devices or debugging code, this is a great place to start.
Hub logs:
https://graph.api.smartthings.com > My Hubs > List Events > From Hub
Great place to see hub connectivity all PING’s (I’m Alive) and hub disconnect/reconnect messages can easily be seen here. These entries are historical up to 7 days
Device logs:
https://graph.api.smartthings.com > My Devices > (Choose a de…
