nathancu
(Nathan Curtis)
September 4, 2020, 10:23pm
9
You have to create a custom presentation and device profile that specifies the display of your device, then ise that to create a VID, then stuff that back in your DTH. Its all detailed in Jody’s tutorial here:
Overview
At SmartThings we want to provide tooling to allow developers to get their device integrations working in the SmartThings app. These changes will allow an integrator to move from using custom commands and attributes to custom capabilities.
DTH Migration For Custom Capabilities
In order to follow along with the example set forth in this guide, you will want to have the CLI set up, so make sure that you take this step first.
You can download the CLI here from the releases tab and read more about it in the README .
It is also recommended that you familiarize yourself with the concepts:
Custom Capabilities
Capability Presentations
Walkthrough
We are going to walk through a simple example of updating our Device Type Handler (DTH) so that devices installed with the DTH will be …
