I can’t seem to see an answer for this but I have a lot of pistons using CoRE right now. If I install WebCoRE will they show up in there or do I have to add them all in manually and delete from CoRE?
You will have to move them all across to webCoRE.
Start with your simple ones and disable the CoRE equivalent until you are happy they are running OK.
Once you get into it I think you will find things easier.
Also if you have lots of similar CoRE pistons, once you have your first webCoRE piston you can duplicate it and then amend it.
Makes things easier.
So I have to manually redo them all in WebCoRE? There isn’t an import feature? Is this the forum to ask questions about pistons?
Jane, yes… you will need to manually recreate each piston in Webcore. There is no mechanism for exporting/importing.
Better place for asking Core/WebCore questions is in their new forums…
Sorry but you have to redo them all.
Thanks! I am signing up now!
Be sure to check out their Examples section. Lots of great pistons and a good place to get an idea on what you can accomplish with webCoRE.
