[DEPRECATED THREAD] webCoRE Beta Milestone 1
This was from back in May. Things have since changed with the addition of the storage app. But this should clear up what is bothering some people. Also please move any further discussion to the non deprecated thread. [DEPRECATED] webCoRE Beta Milestone 2
Did anyone make any progress with this? I’m trying to use this template but webcore continues to say that ā€œthe piston is not subscribed to any eventsā€. Can a piston subscribe to a boolean variable??
Your question is best suited over here. Post over there with what you are trying to accomplish and what you currently have. A lot has changed since I did that sample.
Ever fix that? I’m at the same spot and unable to find a resolution
@Fredrik
This is ancient however I curious on the detail steps you did to fix this. I have the same issue with the wemo insight handler not being detected as a power meter under Core/WebCore.
did you do those in any order: reinstall handler, removed wemo connect, then installed wemo connect again?. I’d love to start working on my Wemo Insights and WebCore/Core.
You might get more traction if you post on WebCoRE forum.
After a little more of reading and running through 100 messages found the answer. Change the capability in the code from ā€œsensorā€ to ā€œpower meterā€. Testing now
we can only do so much. lead a horse to water. you know.
