Alexa, Tell the master bedroom to turn off the lights.
My profile name is masterbedroom.
Use the main intent to control individual devices (at this time).
Alexa, tell home to turn off the vanity light.
Got itā¦ I guess (more of a trial and error thing) the question is whether ES will get confused when a device name shares a similar name as a profile name (i.eā¦ masterbedroom profile and master bedroom light).
Trial and error is a good thing. Each person speaks differently and sound different to Alexa.
Best advice, try it. See what works for you.
If you find something that isnāt listed in the wiki, let us know.
Iāve just tried those exact words. Doesnāt work - she canāt find a device called āgarden lightsā is the response I get
(and the reason I selected āgardenā to test is I have no other devices named āgardenā¦ā)
Post a picture of your logs
This will work, eventually. It takes pronunciation practice. Keep emphasising on IN the garden until you teach Alexa to map it directly to EchoSistantā¦
As for the rest of your cases, the responses you have received are from Alexa official integration. Unfortunately smart home integration takes priority over custom skills. The fact that you have more than one device that has garden in its name, caused the confusion in Alexaās official skill. The confusion that Echosistant is trying to avoid by repeating back to you what Alexa heard and giving you a chance to emphasize on the word Alexa missed the first time.
To answer to @JDogg016 question, yes! EchoSistant does eliminate, to the best of its abilities, the confusion based on invocation, with the caveat that EchoSistant relies on Alexa to provide accurate translation.
You donāt need to add ātheā to your Profile. Naming the intent bedroom, and calling the skill IN THE bedroom works. In my tests, I found that adding THE when calling out the skill actually works better.
No! It will not get confused. Thatās why device control goes through the Main skillā¦tell home toā¦and group control goes through the Profile. Two distinct processors that donāt interfere with each otherā¦And if user mistakenly calls a Profile action through Main Skill, EchoSistant asks for clarification on what you meant. Now there is a limitation to that. In the sense that Alexa cannot switch between profiles on the flyā¦If you accidently called the Main intent, when Alexa asks if you want to try again, it WILL NOT be able to fire actions on a Profile. It requires the Main session to end, and a new Profile session to begin!!!
@bamarayne good for mentioning in the wikiā¦
The responses you are getting are from the official integration not EchoSistant. If Echosistant doesnāt find the device it would say:
āIāve heard the command named āonā and the device āgardenā but I was unable to take any actions, would you like to try again?ā
OR
āIāve heard the the device named āgardenā but I was unable to take any actions, would you like to try again?ā
OR
āIāve heard something but I was unable to take any actions, would you like to try again?ā
Got it! BTW if nobody said it yet, thank you for taking the time to listen to all our silly questions.
This is an example of a typical profile that I have in my system.
Profile configuration for messages and group device control.
Profile Name āLivingRoomā
This profile allows me control over the ceiling fan, group light levels, and group light colors.
I am also able to send messages to the speaker named "Living Room Speaker"
I have individual control over each device in the room as well using the Main Intent.
The following commands are all tested and work for me. You may have different results
based on accent and if youāre male or female.
These commands work for this profile:
Voice Messages
Reminders and Recordings
Delayed Actions Commands
Group Device Control
Color Devices Control
Ceiling Fan Controls
Individual Device Control
No silly questions. In all honesty itās made me think more about the logic process and ensure I give a complete write up of how to do things.
Which logs do you want to see and in response to what action?
As for practicingā¦I donāt think I can practice anymore, Iāve said various things hundreds of times this evening, without success, and Alexa is having none of it. I think sheās fed up with the sound of my voice now!
did you read the post above with how to set up the profile and what commands to use?
if you do whatās in that post, and it doesnāt work, then there are other issues.
No worries, youāll be paying back with your feedback to make EchoSistant better! There are no silly questionsā¦
Olease take time to read my comments also, you are not using EchoSistant. You are actually ising the official integrationā¦
There will be no logs from EchoSistant @bamarayne
I feel I need to start over with a new test profile. Iāll try and select devices that Alexa canāt confuse for anything else.
I donāt have a speaker, so canāt test the voice feedback or custom messages.
I pretty much only have lights I can play with. Oh, and heatingā¦but donāt even want to go there yet. I just need to get a simple test profile working before I try anything more complex.
Iāll try and replicate some of the actions in the post you refer to. But Iāve lost the will at the moment! Iām feeling that I have no clue what Iām doing, despite the assistance I have had on this forum. I appreciate that
I really want this to work.
EDIT: And yes, I probably need to read everything again, including the comments on this thread. Patience is my weakness!
My setup was going smooth until I finished the āmain intentā and get a Lambda Response of: The remote endpoint could not be called, or the response it returned was invalid.
What am I doing wrong? Iām trying to get āAlexaā to open āgarage bayā and lock/unlock āgarage bayā
Have you completed the main intent skill setup?
Please check your API patth in Lambda code. It may be different. Also double check that token id and smart app id match with ST.
Sure you do! You have a ohone to send text to. And you have lights to create groups. Itās the only way you can say lights off in the Bedroomā¦
