Announcing version 2.2.5 of Ask Alexa
Happy Cinco de Mayo (for those in North America!).
I am pleased to announce the 2.2.5 version of Ask Alexa. In this version I continue (along with help from the community) to evolve the application to allow more conversational syntax, along with adding more functionality for existing and new devices. This is JUST an IDE update and another couple extensions (Also in the IDE). NO Lambda updates, however, you WILL need to go through Settings>>Setup Variables for the new functionality to operate. This is very important and about 50% of the problems I see are people not updating their slots after an upgrade. And while not required specifically, it is always a good idea to ensure you have the latest utterances.
Please note that I updated the Lambda and Message queue code a couple weeks ago. You should have already upgraded. If you havenât the newest version will âremindâ you that you need to upgrade.
I recommend you read the forum post here before upgrading: [RELEASE] Ask Alexa . YOU WILL LOSE your voice and weather reports if you do not follow these steps. If you inadvertently donât do this, load in the old 2.2.4a code back into your IDE and do the steps outlined in the post.
The next update will probably be 3 -4 weeks (or more) away. However, I will push bug fixes out if you report them to me! And I will always be on the forum to harass
PLEASE NOTE: Now that this app is rather stable (It is now almost 1 ½ years old!) now I will be updating it less frequently except for bugs and new features. I am waiting for Amazon to release their âpushâ notifications where some amazing stuff will happen with this app. Until then, if you do have a great feature idea for this app, just let me know.
Other additions to this new version include:
- Bug Fixes - The normal thingsâŚsilly misspellings, logic errors, bug reports.
- Code Optimization - Always finding better ways to do things in a shorter about of code. I reduced the code about 1000 lines by moving the the voice and weather reports to extensions. This speed up the execution of Ask Alexa by about 10%-20%!
- Expanded thermostat reporting Allows for the voice reports to include more detail about the thermostats. Suggested by @twodaend
- Updated SmartThings Icons SmartThings has adopted a new solid blue icon for itâs logo. Ask Alexa now reflects this logo in the Control Macros area (and in the documentation).
- Default white (Kelvin) controls Allow for the 4 defined whites for Kelvin lights to be configured by the user. Suggested by @M3Rocket
- Nest Manager Name Change Per the author of NST manager, changed the name of the app internally to comply with the new name. Also fixed a small report issue when Ask Alexa is in brief response mode. Thanks @tonesto7
- Ask Alexa Extensions - To allow for even more options in the future, the architecture of Ask Alexa is evolving to allow what I am calling âextensionsâ to be accessible via the main app. Just like child apps in other applications, these can be added to Ask Alexa to give even more functionality to the main program.
Weather Reports Weather reports are now their own extension. This is not really a change from the old versions except it separates the weather reports from the voice reports, and adds the ability to just have advisory reports without any other parameters. This WILL be important as I develop the next extension, schedules. This will allow you to do things like have inclement weather alerts come through to the message queue (which you can be notified via lights or even a playback on a SmartThings connected speaker.). When push notification comes out, these alerts can be sent directly to your Alexa Connected Devices. I want to thank @storageanarchy again or the weather reporting code he developed for Ask Alexa last year!
While I have separated the weather reports from the voice reports, you can still use them in the voice report macros. Simply use the Weather Report name as a variable in the output. - Voice Reporting Voice reporting as also been moved out of the macros section and put in itâs own extension. Weather reports can STILL be included with the voice reports through a variable or the âinclude other reportsâ area. Thanks also to @fireheadman for suggested putting message queues into the voice report (other reports) section (and thanks for beta testing this).
- Flash Briefing With the additions of new Weather Reports you can use any of them as the output of the flash briefing. In addition, you have always been able run group macros (now called Extension groups) from the flash briefing. This allows you to create groups of macros and extensions to run at the same time. Weather reports can be part of these extension groups.
Installation
For those with IDE integration with GitHub, simply update the repository and you will have the latest code for the SmartApp itself. However, for ALL aspects of the application follow the original instructions for installation to ensure you get everything updated properly:
The wiki for this app is here: http://thingsthataresmart.wiki/index.php?title=Ask_Alexa
Support
All of you have been great in asking very relevant questions and making suggestions that I end up using. Here are some helpful tips on usage and support:
- Sometimes it works best if I can work real time with you. To facilitate this, I have created a Slack channel: https://askalexa.slack.com. Using this tool is easy and will allow for real-time collaboration to solve the problems faster. To use this feature, I must invite you to the Slack channel. This will not be for normal questions; please use this forum for that function.
- The Echo, as it is designed currently, cannot react to switches opening or other actions within SmartThings. She will do things for you, but only at your direction and at the time of the request. The delay timer mentioned in the control macro happens at the SmartThings hub, not within the Amazon Alexa control. See the new Message Queue functions for similar functionality with Big Talker!
- When evaluating new features I will typically ask for a valid use case. If it can be used by others to bring them value I will put it on my list of future revisions. Not all suggestions will be used and many times I add aspects of the request.
- There are no dumb questions, but many of the questions you may have were probably answered in the year since the initial release. Please take some time to go through the forum and the wiki if you have issues. And donât be offended if I give you the specific area of the manual that answers your question. I have spent almost as much time on the documentation as I have on the app. Finally, there are some big fans of Ask Alexa that know almost as much as I do. They can also help.
- Feel free to send me forks of utterances or even code revisions. As mentioned above, if it adds value to the overall program I will try to include it. This also goes for the wiki documentationâŚwhile I have spent over a year creating this document, I am open to it being improved; I know there are probably still grammatical errors or syntax issuesâŚIf you find them, fix themâŚI will include your name (if I can) in any fixes submitted.
- If you find a bug or a consistent crash please help me track it down by giving me repeatable steps to reproduce it. A non-reproducible bug, many times, indicates other areas that may be at fault besides the app. If you watch the live logging and see a red error with a line number, that is very helpful to me! However, I will need a full screenshot and not a copy/paste of the text. But be careful about revealing your OAuth and AppToken in your public posts. People can control you house with that information. You may want to blur that out.
As mentioned above, revisions will be less and less now. And with the code base now unified, I expect less and less additionsâŚespecially as I partner with other application developers to ensure their strengths can be brought into the notification model of Ask Alexa . Any and all suggestions are still on the table for addition.
To prep for the next version, be sure to take some good notes about any weather voice reports you have set upâŚI will be moving the weather piece to it own extension app. However, it will still be able to work in any voice report you have set up. Then, the fun begins with addition another extension after the next one!
As always, I appreciate any public accolades or even donations to my PayPal account: https://www.paypal.me/mstruck . And, if you are so inclined, I also will accept bitcoins (or fractions thereof) if you have any laying around. My wallet ID is: 1CMgaiKgBfojTBCLpHLfa9KvcrW3cNxVpm
Enjoy.
