Great job!
Yes, as mentioned in this post, the team is working on a fix. Iâll let you know in case I receive feedback about that.
The 3 custom capabilities that I have created work fine in automations in the Action Part (then), but in the Condition part (if), it doesnât work.
Once the condition is selected, it shows as unknown condition.
With this error, it does not allow saving the automation.
Double check the capabilities presentations, in particular the âconditionsâ sections. The âlistâ object should include a line of the form:
"value": "attributeId.value"
Without that line it wouldnât know what attribute value it is supposed to use.
The similar structure in the âactionsâ section doesnât have that line, it has "command": "commandName" entry instead. Could you have missed that difference?
It seems that I have that error in the capability presentation:
"automation": {
"conditions": [
"label": "Progressive ON",
"displayType": "list",
"list": {
"command": "setProgOn",
"alternatives": [
"key": "yes",
"value": "yes"
"key": "no",
"value": "no"
"actions": [
"list": {
"alternatives": [
"key": "yes",
"value": "yes"
"key": "no",
"value": "no"
It would be to replace in conditions the command line by attributeID.value
I will try it
Thank you
Just noticed I left the quote marks off. I am too used to writing YAML now. Just for clarity, here is an example I have with a âlistâ condition.
"conditions": [
"label": "STHM Status",
"list": {
"alternatives": [
"key": "armedAway",
"value": "Armed (Away)",
"type": "active"
"key": "armedStay",
"value": "Armed (Stay)",
"type": "active"
"key": "disarmed",
"value": "Disarmed",
"type": "active"
"value": "sthmStatus.value"
The example helps!
The documentation that is there is so bad
Thank you
What do you consider should be improved in the documentation?
Thereâs an example of each display type for the different presentation sections, for example, this is the one for the list in âactionsâ:
Tip:
The âconditionâ section of the automation is used to compare a capability value, so itâs easy to differentiate the configuration from the âactionâ section because the last one uses the property âcommandâ.
Being precise in giving qualifiers in a language that is not yours is not always easy!
I understand that the documentation in times of transition is not easy to be 100% updated.
Many times it is not that something is missing, it is that it is not easy to find it and when you find it, as in preferences, it is valid for groovy, it is not 100% valid for Edge Drive.
Also how and where to look can help.
If you go to the Edge drive manual, you cannot use the search, it gives page not found error to everything you are looking for.
If it werenât for your help, it would be a lot more difficult, not only for me, from what I see daily in the forum!
If so many people find it difficult to make the custom capabilities, their presentation and the final view presentation of the device, it is that something is not so clear in the procedures.
In my case the lack of knowledge also counts.
Thanks for your help
I modified the presentations of the 3 custom capabilities and got it to work after I was about to quit.
I created a new configuration presentation of the device to get a new âvidâ, but it gave me exactly the same.
I verified in the API, that the presentations were updated with the âvalueâ instead of the âcommadâ.
I thought, well he will have modified the data of the custom capabilities with the same vid.
When testing it kept giving an âunknown conditionâ error
In the end it occurred to me to modify in the .json to create the device presentation the color temperature value from 2700 to 2699.9 in the details view and it already gave me a new âvidâ.
Tried, everything worked.
It doesnât seem normal to do this for update something data in the custom capabilities.
Is there another way to do it?
There are still a few more issues with the custom capabilities driver.
As I mentioned before it installs fine and kind of works however if I go to the SmartThings Android UI and repeat adding and removing a device which is controlled by this driver in about 40% cases after adding it, instead of displaying the custom capability value on the dashboard and on the detailed view it just displays the word âConnectedâ and never displays the custom capability value. However if I remove it and add it again there is a big chance that it will display the expected capability value. What can be wrong? Why might it happen?
If I go to the detailed view of the SmartThings Android UI and try to change the value of the custom capability it displays an error âA network or server error occurred. Try again later.â It is unlikely a network error. It ALWAYS displays this error. Why might this happen? Once again my driver code is very close to the custom-capability sample with a few modifications and a custom capability using a list of values. It is sort of a hybrid between the hello-world sample and custom-capability sample.
The curious things is that the virtual device controlled by this driver works fine in the rules. I can change the value of the device as a result of a rule execution and I can trigger other rules by the change of the value of this custom capability but I cannot change it via UI. However if the value is changed by a rule it is displayed correctly in the UI. I donât really see major difference from the hello-world driver example which works entirely fine and I can change the value, turn it on and off from the UI. In the case with my driver there no logs at all when I try to change the value from the UI. I would expect to see at least something like what I see with the hello-world âTRACE Hello World Received event with handler capabilityâ but there is nothing at all in the case with my driver as if the requests donât reach the hub at all.
UPDATE: I just figured out the cause of the first problem. It turned out that I had 2 slightly different versions of the driver installed and even though packageKey of them was different, so that I had two distinct drivers in the system, the name of the profile and the name property in the profile was the same and that name was used when a virtual device object was created. Apparently when I added a device via the UI, it arbitrarily started one or the other driver first, it created a device and at the moment the system started the other driver the device was already created and it did nothing or maybe it recreated the device. In any case it would lead to 50% chance of instantiated device of one or another driver. The other problem still persists.
Ok, Iâd like to give a further look at your configuration. Can you please share your driver source code (not the packaged version) in a zip file to build@smartthings.com?
This happens when you include the same capabilities, to force creating a new VID, you need to add/remove capabilities.
However, you should see the changes if you follow the instructions I shared above.
Update: After more tests, I noticed there are some elements of the presentation that are updated almost immediately but others seem to get stuck in the previous version. (Android)
In iOS, the update is not so active so Iâll also mention this.
When you experience this again, you can open a new post to discuss the specific configuration where the issue was present.
Thatâs strange. Everything I try to e-mail to build@smartthings.com gets back as undeliverable.
Donât worry, I sent you an email. Please check your inbox and reply to me there. Thanks!
Considerations to share about what I have observed when using custom capabilities:
When you create custom capabilities and their presentations you do not need to create a Device Configuration Presentation (Vid) to add it to the profile metadata.
You only need a device configuration presentation (vid) if you are going to modify the presentation of a standard capacity, for example the color temperature capability default ranges.
If you modify a presentation of a Custom Capability and you want see new presentation on your device, you have to do the following:
uninstall driver â unpublish driver â delete driver and do new package â publish â install.
This is a problem when you want to publish a new version of a driver that is in use, since it creates a new driver ID and does not consider it a new version, it considers it a new driver.
- If you have changed something in the presentation of a custom capability that is used in a profile that has a device Vid in the metadata, you do not need to create a new vid, you just have to follow the steps described in the section 3 and you can use the same vid.
When you use custom capabilities, it is necessary to create a device-config, otherwise, the app generally displays âconnectedâ instead of the capabilities.
As per your description, I understand that youâre not creating the device-config and the capabilities are displayed, is that correct?
Yes, but only certain elements can be modified. Eg. available enums and range. The labels of the standard capabilities cannot be modified.
This shouldnât be necessary. It depends on what you change from the capabilityâs presentation, but when you re-create the device-config (which doesnât generate a new VID), the device UI should display the new change (mostly on Android - closing and opening the app again helps with the refresh).
For iOS, you might need to re-install the device.
This is related to point 3. If youâre having issues with the update of a presentation, please share your configuration so we can discuss it further.
Indeed I can use the custom capabilities only with their individual presentation.
They are shown and work perfectly in details, automations, with their units and maximum and minimum ranges, if have them.
I just need to create a VID for each of the three profiles of the standard ColorTemperature capability, with different ranges.
Can they work because they are custom capabilities that do not require any communication with the device?
They are capabilities that send commands from the App to set values in the driver and driver is the one that communicates with the device with the standard capabilities.
When I modify a presentation of a custom capability that I am already using on a device, for example when I corrected the error of putting âcommandâ instead of âvalueâ in the automation condition in the capability presentation, and I want that modification appear in the app, the only way that has worked for me and is updated immediately in app:
uninstall driver â unpublish driver â delete driver and do new package ID â publish â install driver.
This generates a driver with a new Key ID and is compiled from scratch with the new modifications of the capabilities presentations.
To generate a new VID with the same capabilities, but modified, the same thing happens. If a new package is not made, eliminating the previous one, it does not generate a new VID
If you uninstall the device from the driver, re-do package â publish â install, the presentation in the app is still the old one and in the API you can see that the new capability presentation modification is updated.
I donât know if waiting 12 hours it will update, I donât have so much patience to see the changes. ![]()
For about the last year, device presentations have automatically been updated with any changes to category presentations. As 2020 was SmartThings âYear of the Cacheâ it unsurprisingly can take several hours but it does happen. It can then take another twelve hours for the apps to decide whether theyâll take any notice.
On the face of it, it does seem that it ought to be possible to have an API command to reconstruct the device presenation.
When you do a smartthings capabilities: presentation: update in the CLI in the API, it updates correctly.
I donât know very well how it works, but the problem seems that in order to force use of the presentation of the modified capabilities, the Hub has to see a different driver ID or different VID.
In fact, if you keep redoing the driver package generating the same driver ID and pair it with other different devices, it also shows them with the custom capability without updating.
If you manage to generate a new VID with the same capabilities, the modified capabilities displays are also correct.
For example, I managed to generate a new VID by modifying a Color Temperature range from 2700k to 2699.9k for detalls view in .json file. With this it shows everything well with the same driver ID
Hi @nayelyz Iâm really struggling, I hope you can help.
I started off with using the HelloWorld example as a driver and have customised from there.
My device was working and my custom capability was visible in the automation screens of the app, but the capability never appeared on the other screens.
What I have done
- Removed the switch capabilities (that was there from helloworld and added in my capability as well as a preferences section
- created a presentation for my capability
- created a device config presentation
But for some reason I just canât make it work, my driver packages, publishes and installs fine but in the app all i see is status: connected.
Where do I start on debug what is wrong?
I have tried many of the things in this thread, but i dont seem to be able to solve the problem
Many Thanks
Louis
Edit: my capability is universevoice35900.harmonyCommand
My VID is 2e9ad144-9f9e-356e-8dc9-b97ec18bedb7
