Thanks! Want to try and move everything from Notify Me When to Pistons. Thanks in advance.
Basically to replace Notify Me When I need the push notification to say something along the following. I have the piston setup just need to know what variables to use.
{device name} was changed to {device state (open/closed}
Regarding the osram lightify strips, any rules or Pistons regarding these, these are the only ones left that I have not transferred from rule machine. This is because I’m having a hard time setting the color temperature with core for these. With rule machine, I have them turn on with motion at a color temperature of 3890, but I can’t do this with core for some reason . It comes up a different color… different shade of white.
It’s the exact same action in a rule machine and Core but for some reason core is not recognizing color temperature of 3890 for these strips.
When I look at the device individually in the st app, it comes up as the color “moonlight” after being set by rule machine which is not an option under core for colors. maybe that’s why?
Circled in red is the lights after setting them with Rule machine with a color temperature of 3890 when motion is detected.
With core, After I set them to a random color, after sunset and no motion for five minutes, I cannot get them to come back on at this color using core.
If they are on a random color with core, and then I trigger them with motion, all they do is get brighter with the same color that was already randomized. So for instance if they were randomized at blue because there was no motion for five minutes, and I walk in front of the motion sensor they just turn a brighter blue not the white but I can do with rule machine.
Core piston said if motion, set color temp to 3890. Still they only brighten whatever randomized color was last on.
So my WAF is not a factor tonight. Because she is out of town. Kids are asleep. I’m bored. So I just think I’ll go outside and watch my garden spots change colors and drink a beer,!
bamarayne
1608
I just finally actually installed mine. I was so excited I just ran extension cords!
I love these lights!
But, I’m having a lot of trouble with them in CoRE a far as colors. Actually, all of my color devices…
Before his infofiends’ device type, I was using core to set them to a random color every seven minutes overnight. What kind of problems are you having?
So something strange is happening tonight. My piston that changes my garden spots color every three minutes is timing out quite regularly. (must be the server I am on because I’ve had lots of Pistons with the date and time CONDITIONS not firing properly -thanks ST). But when I open the dashboard To check on it in my web browser, it’s automatically refreshing or recovering. It will say overdue by X number of milliseconds, and then it will refresh and start running again . Did something change? I know Ady
updated the app, but for some reason when I open my dashboard the piston is refreshing automatically
I am trying to setup a piston that will do a list of actions when SHM has an intrusion activation. I can not find anything that can be used as a trigger that will change back to its original state (off) other than using a siren. Any suggestion?
