Controlling device over OAuth using device label
Since my SmartThings scheduling hasn’t worked in the last 4 months, I’ve sort-of taken things into my own hands and created my own scheduling system. It’s basically a SmartApp from their OAuth tutorial - no frills. Then I have a script on my server that uses cron to run the script every miniute. Inside the script are a series of time’s where certain events trigger.
When I add a new device to the SmartApp for control, I have to go through some processes to find the device ID.
My question is: is it possible to control a device using the device name (or label)?
Here’s where I am at today:
I have my switches mappings like below:
	path("/switches/:id/:command") {
		action: [
			GET: "updateSwitch",
Which calls this function (admittedly, I think I found this portion on GitHub not the tutorial, but the concept is the same):
// From the HTTP GET to update switch status
void updateSwitch() {
	update(switches)
private void update(devices) {
	log.debug "update, request: ${request.JSON}, params: ${params}, devices: $devices.id"
	//def command = request.JSON?.command
	def command = params.command
	if (command)
		command = command.toLowerCase()
		def device = devices.find { it.id == params.id }
		if (!device)
			httpError(404, "Device not found")
		else
			device."$command"()
This way I can easily run https://graph.api.smartthings.com/api/smartapps/installations/my-smartapp-id/switches/My+Switch+Name+Here/on?access_token=my-access-token
Then I guess once I do find the device name, I would need to convert the name to the ID to do the controls?
Any tips are appreciated.
Iterate over the switches, find one with the matching label and send a command to it.
@625alex I tried that but didn’t have any luck.Then I realized I was using it.label and it.name, when I should have been using it.displayName.
Got it working (until I break it again) :smile:
