Hi everyone, I have been trying to make a solution to use all of our existing door contacts that we purchased through ADT with ST. To do this, I am using a Raspberry Pi ($35) and a $5 wifi dongle. I used a library called pi4j and used java to make a web application that takes two gpio ports and checks if they broadcasts if they are open in JSON format. Here is an example of what the json looks like.
{"Door1":"true","Door2":"true"}
I created a device type called Door Security and it just makes tiles for each boolean value. This was just so I can get the data into smartthings. I am brand new to smartthings so I have no clue how to write any code using the IDE. Neither do I have experience using Groovy but I have about two years of experience on Java. I run the code on a new device and named it Raspberry Pi. When I hit the refresh button, as it should, it sets the device network id. However, it doesn’t log anything inside the live logging… I took at Nicholas Wilde’s berryio smartthings integration and that didn’t work, but I decided to use the device type as the boilerplate of mine as I would only need to get the tile of where it extracts the GPIO from the berryio json. Here is my device type:
import groovy.json.JsonSlurper
import com.google.common.base.Splitter;
import java.util.List;
import java.util.Map;
import java.util.Map.Entry;
preferences {
input("ip", "string", title:"IP Address", description: "192.168.1.105", required: false, displayDuringSetup: true)
input("port", "string", title:"Port", description: "8080", defaultValue: "8080" , required: false, displayDuringSetup: true)
metadata {
definition (name: "Door Security", namespace: "leoforney", author: "Leo Foney") {
capability "Contact Sensor"
capability "Refresh"
simulator {
// TODO: define status and reply messages here
tiles {
standardTile("door_1", "device.contact", width: 1, height: 1) {
state("open", label:'${name}', icon:"st.contact.contact.open", backgroundColor:"#ffa81e")
state("closed", label:'${name}', icon:"st.contact.contact.closed", backgroundColor:"#79b821")
standardTile("door_2", "device.contact", width: 1, height: 1) {
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat") {
state "default", action:"refresh.refresh", icon: "st.secondary.refresh"
main "door_1"
details(["door_1", "door_2", "refresh"])
def map = [:]
def descMap = parseDescriptionAsMap(description)
log.debug "descMap: ${descMap}"
def body = new String(descMap["body"].decodeBase64())
log.debug "body: ${body}"
def slurper = new JsonSlurper()
def result = slurper.parseText(body)
log.debug "result: ${result}"
if (result){
log.debug "Raspberry Pi is responding!"
if (result.containsKey("Door1")) {
log.debug "Door1: ${result.Door1}"
if (result.Door1.contains("true")){
log.debug "Door1: open"
sendEvent(name: "door_1", value: "open")
} else {
log.debug "Door1: closed"
sendEvent(name: "door_1", value: "closed")
if (result.containsKey("Door2")) {
log.debug "Door2: ${result.Door2}"
if (result.Door2.contains("true")){
log.debug "Door2: open"
sendEvent(name: "door_2", value: "open")
} else {
log.debug "Door2: closed"
sendEvent(name: "door_2", value: "closed")
// handle commands
def poll() {
log.debug "Executing 'poll'"
getRPiData()
def refresh() {
log.debug "Executing 'refresh'"
getRPiData()
private getRPiData() {
postAction("/")
private postAction(uri){
setDeviceNetworkId(ip,port)
def hubAction = new physicalgraph.device.HubAction(
method: "POST",
path: uri,
headers: headers
)//,delayAction(1000), refresh()]
log.debug("Executing hubAction on " + getHostAddress())
//log.debug hubAction
hubAction
// Helper methods
def parseDescriptionAsMap(description) {
description.split(",").inject([:]) { map, param ->
def nameAndValue = param.split(":")
map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
private getHeader(){
log.debug "Getting headers"
def headers = [:]
headers.put("HOST", getHostAddress())
return headers
private delayAction(long time) {
new physicalgraph.device.HubAction("delay $time")
private setDeviceNetworkId(ip,port){
def iphex = convertIPtoHex(ip)
def porthex = convertPortToHex(port)
device.deviceNetworkId = "$iphex:$porthex"
log.debug "Device Network Id set to ${iphex}:${porthex}"
private getHostAddress() {
return "${ip}:${port}"
private String convertIPtoHex(ipAddress) {
String hex = ipAddress.tokenize( '.' ).collect { String.format( '%02x', it.toInteger() ) }.join()
return hex
private String convertPortToHex(port) {
String hexport = port.toString().format( '%04x', port.toInteger() )
return hexport
The tiles do not change from the JSON and my live logging doesn’t work so I can’t tell any debug info. If anyone can help out that would be awesome, thanks in advance…
