Chain physicalgraph.device.HubAction calls?
Hey folks,
New user here. Quick question for you… is it possible to have two physicalgraph.device.HubAction calls?
Here is what I see:
I do have command that I run, that spawns physicalgraph.device.HubAction with GET request -> reaches parse (as expected) -> based on the output from the previous command (headers and body) I do want to run another physicalgraph.device.HubAction GET. That runs fine, although I don’t get any data back, even when two queries looks exactly the same.
In other words:
I hit the button in my device -> physicalgraph.device.HubAction is called (GET req) -> parse reached, output parsed -> spawned another command based on the output -> physicalgraph.device.HubAction … not reaching parse() anymore with updated output - even if the second query is the same as the first one. Everything in one call.
Is that expected? [ cc: @pstuart ]
I believe there is a minimum wait time between requests. Try the second request after a runIn() command for like 60 seconds.
Any reason why you can’t do both queries at the same time? Seems odd to need to query same device that quickly.
Ok… that would explain a lot. I was working on a www digest authentication and to get the token you need to have two calls in a row. Code is fully published and available in that thread: Samsung SmartCam: SNH-P6410BN, SNH-E6440BN and SNH-1011ND (+WWW Digest auth) (tested and working)
