Unfortunately not but SmartThings has said they’re looking into adding different permissions for secondary user accounts. I wouldn’t hold my breath on it though.
Also, are you using the code that I have linked or the actual official code from @ethayer? I only ask because keypad functionality is now merged into the main code so you don’t need to use my custom code anymore (I won’t be updating it in the future).
Out of curiosity is there any reason to buy the X3400 over the IRIS version? Any options that are different or functions that work on one and not the other. I am only using it to arm and disarm SA. At this time I don’t have any locks and if I am reading everything correctly Lock Manager is for door locks. Is that correct?
It’s main function is to control door locks and manage user codes. I added the keypad support in order to leverage the user management functionality and allow common codes between locks and keypads (assuming you use a 4-digit code).
Thanks, that is good to know. I just wish the IRIS motion sensor was more sensitive I have to be 4 to5 inches in front and then wave my hand to awake the keypad.
it is proximity sensor, not motion sensor. I is feature, you have to be about 10-20 cm far. if it lit every time is somebody going around batteries will drain pretty quickly.
I understand that, but my friend has the IRIS system and the proximity sensor works at least 8 inches away. he just has to move his hand toward the IRIS keypad and it awakes. No waving etc.
I’m not so good with code, does anyone know if the X-3400 app runs the routine (when set in settings) in addition to changing the SHM alarm state? @mitchp?
Trying to configure an exit delay, but I’m not having much luck. I’d like the Arm/Away from the keypad to just run a routine, but I think it’s also setting the SHM alarm state immediately. I just don’t understand the code well enough to know.
I have built in exit delays in the lock code manager SmartApp by ethayer. It’s a bit more complicated than the keypad only one and allows use with door locks.
Thank you Ben. I was able to take the original 3400-X code and copy back the arm delay info from ethayer’s code to give myself a custom solution. I added independent delays for “stay” and “away” modes
I don’t know enough about programming to figure this one out, but I’d love to have this feature as well. I have a routine in ST that trips a virtual contact sensor, which will trip the alarm when armed. I just need a way for the keypad to activate it.
Go to post 526 it tells you what you need for the IRIS that is what I am using with no problems. I used the X3400 at the bottom instead of lock manager as I am not using any locks, but either works.
