Pandora! ! ! ! ! !
As mentioned in the presence FAQ, I use Ibeacons for presence. Very reliable if you want a small detection zone.
I plan to implement these for individual rooms of the house⦠I hope. How small of an area can you make with them?
Is everyone at your house getting mandatory implants?
Now that would be awesome!
2 inches square with perfect transmission.
The Apple standard provides for three distances: immediate, near, and far. Which usually translates to a few inches, about 3 m, and further than that up to about 15 m.
However, and this is super important and every beacon manufacturer will talk about it, itās not actually a distance. Itās a measure of signal strength. You could be standing 8 inches away and if you drop a cookie sheet in between your phone and the Beacon suddenly you will register as āfar.ā
So thereās some trial and error depending on local interference. And conditions can change. For example, if I park my wheelchair in a specific place in my living room I block reception.
But if youāre not trying to get absolute precision, it works pretty well.
And some beacons, like Estimote, let you set a custom transmission strength, which let you vary the detection zone.
Ibeacons are also designed to let you define a āregionā of multiple beacons, so that you could cover an entire house with four beacons and have it all count as one region. still not mesh ā ā each individual beacon is point to point. Itās just that the receiving station app, which evaluates what to do with the information about the beacons, knows to count them all as part of the same region.
Entirely separately, the Estimote brandās newest model has a ālocationā feature which uses three beacons to triangulate a personās phone in the room and gives you pretty accurate positioning. But it does require three beacons per room.
http://developer.estimote.com/ibeacon/tutorial/part-3-ranging-beacons/
So there are different options that you can play around with. Just remember that Bluetooth is a 360° signal, so if you use āfarā itās going to pick you up on multiple floors in the building.
Itās on multiple devices. Sometimes itās accurate, other times it takes two days to update.
Key word being small. That doesnāt work for locking doors, changing thermostats, and arming SHM when everyone leaves and disarming when someone comes back. Leave the area and bad things start happening.
You can use multiple beacons to define a region. Thatās what department stores do, so that a person only gets the āwelcome to Macyāsā message when they first enter the store even though they are now 300 feet from the entrance.
But of course that increases the total device cost.
This post is in response to my request for the Sonoff wifi switch above.
āReally hate to post this but thought it the responsible thing to do.
I have had one of these turning on/off my fish tank light for just over a week now.
Tonight it lost association with my hub and I could not control it any more. i could turn it off and on via the button.
Then the light started flickering about an hour later.
It was now getting a bit warm.
I have removed it from the circuit and I will bin the other 2 that I have installed.
I am in the UK running 220V.
It could just be one faulty unit butā¦
Just thought it my duty to tell the forum what I have foundā.
Also thanks @JDRoberts for the advise about the swiidinter cord switch. I know these are more expensive but more order has just gone in.
Not sure Iāve given enough thought on this but Airfoil would be nice. Would like ability to turn on/off speakers, adjust volume, simple play/pause/skip functionality, and use it to connect simulated push buttons for quick access to presets. Have people had much luck with the other options for Smartthings + Airfoil (& + VLC Thing)?
Integration with Networked Tuners/Receivers. Where you could turn on the unit, set a source, and adjust volume, etc.
@redloro created a basic but functional DTH for the Yamaha receivers:
Simple SmartApp and Device Type to provide integration for a Yamaha Network Receiver with the following features⦠and now with MusicCast support! Zone Status (on/off) Zone Source Zone Source Control Zone Volume Control NOTE: volume control will mimic the volume levels of the Yamaha receiver using a range of -80ā¦16; if you want to use a range of 1ā¦100, you will need to swap 3 lines in the device type code Zone Mute (on/off) Zone Party Mode (on/off) ** Update 03/12/2021 ** The short story is that this integration is NO LONGER BEING MAINTAINED; please feel free to clone the repo and carry it forward! The long story is that ever since ST rolled out the new app and basically broke support for tons of integrations (including this one), I waited, waited and tried many times to find a good enā¦
Can you not use the harmony hub and integrate it through that?
Of course, but I dont have a Harmony hub, so why pay the extra cash? Also, thatās adding another layer of complexity and lag that isnāt necessary if the receiver can be directly integrated through ST.
True. But I love my harmony!
iRule
Yonomi
SmartTiles
what about PLEG?
Probably already been mentioned countless times but it would be an absolute godsend to be able to copy pistons.
Most of the time, my pistons are slight variations on previous ones so being able to copy a piston as a starter for 10 would be fantastic!
Not really an integration of new hardware but the inclusion of a backup/restore if it is possible?
Someday I would like to upgrade to a V2 hub but the thought of entering in all those Pistons again is painful. As well, the house would be stupid until I did and there goes the WAF.
