RBoy
303
It resets in 2 minutes, any shorter and it may lead to multiple to alarm events due to the way blink currently works
You don’t need to do that, if you want to reset the intruder alert just click on the intruder alert tile and it’ll disable it
That’s because of the ST timer issues, the app sets a timer to turn off the notification in 2 minutes so if the timer fails to fire it won’t turn off automatically. If you’re seeing this issue you should report it to ST support so they can fix the timer issue with your instance. Hopefully the new ST scheduler being deployed in the next few weeks should address it.
Meanwhile, just click on the motion detection tile to reset it.
Do you have any information about using the cameras as a regular motion sensor w/o it taking a video every time and getting a Blink notification? Or is that not a possibility at this time?
RBoy
305
Not yet, it’s a feature being discussed with the blink team but please send in your feedback to the blink support team on their website so they can log requests which will help in expediting things.
I have found Routines and SHM to be very unreliable and am using the Smart Lights SmartApp with RBoy’s app to manage my Blink cameras as individual switches with my presence. It has been extremely reliable and triggers within 30 seconds (See images). I’m hoping that the motion sensor will eventually work separate from the video and also trigger lights quicker so that I can get rid of my other motion sensors. RBoy, great job with the Blink app makes me want to try some of your other apps.
RBoy
308
Thanks and please send in your requests to the blink support team so they tally the requests.
Part of the ongoing discussions with the blink team is eventually look at Blink as a replacement for motion sensors.
Hi Blink Backer,
We have told you that it was coming, and we are excited to announce that it is finally here!!
As promised, starting today (March 24) through March 31 we are offering a special backer-only discount on Blink systems and add-on cameras!
To receive $30 off each Blink Home Monitoring System (any size), go here and use promo code KSDISCOUNT30 at checkout.
To receive $10 off each Blink Add-On Camera, go here and use promo code KSDISCOUNT10 at checkout.
Act now to get that extra camera or two you’ve been waiting for, or to buy a system for those friends and family who have grown jealous of your new peace of mind. Don’t miss out, order today!
Best,
The Blink Team Orders are subject to local taxes.
You’ve made this comment to me before (maybe in the other thread). But tapping that intruder tile actually turns the camera off as well (i.e. it doesn’t just get rid of the intruder message). Obviously I can turn it back on, but is that the expected behavior? Or am I missing something?
RBoy
311
That is correct, it turns it off to disable the alert (not just reset it). But it’s food for thought, would love to get some comments from the community on how it should behave.
Clicking the tile when in intruder alert state should
Turn off the motion detection and disable the alert
Just disable the alert and leave motion detection on
Normally I’d feel bad using those codes since I’m not a Kickstarter backer, but did they happen to come from this update? Since I’m not a backer I just get the “For backers only. If you’re a backer of this project, please log in to read this post.” message. I’m more curious in the update than the $10 off promo code (though I could use one or two more cameras).
However, I’m also a bit annoyed at them because I bought and own the cameras–that pretty much makes me a backer now, right? Kickerstarters already got their perks (cheaper cams), so give me the updates at least!
I could potentially see a use for a separate alarm/intruder tile or for option #2, but for the most part SmartThings should just work correctly so that it goes away reliably after two minutes like designed.
That said, I don’t have any of the alarm features of your app enabled–so I’d prefer to never even see the intruder message unless I enable an alarm. Maybe the “Silent Alarm” toggle should do that? Actually, I just noticed I didn’t have that enabled, so for all I know, it already does.
RBoy
314
One of my friends got a Fisheye view on one of the cameras from Blink. They just RMA a replacement too. Blink is good that way. Thanks for the update @Ryan_Guinn.
