Well it took care of the close every minute issue, but I still have behavior issues:
All zones are set to a min opening of 30
Main
12:44:49 PM: debug checkNotify:exit-
12:44:49 PM: debug notifyZones:exit-
12:44:48 PM: info Main HVAC state changed to: cool
12:44:48 PM: debug notifyZones:enter-
12:44:48 PM: debug dataSet: [msg:stat, data:[initRequest:false, mainState:cool, mainStateChange:true, mainMode:auto, mainModeChange:false, mainCSP:79.0, mainCSPChange:false, mainHSP:72.0, mainHSPChange:false, mainOn:true]]
12:44:48 PM: info PARENT Ouput Reduction Off
12:44:48 PM: info checkNotify- mainOn: true
12:44:48 PM: info checkNotify- mainState: cool
12:44:48 PM: info checkNotify- mainHSP: 72.0, mainHSPChange: false
12:44:48 PM: info checkNotify- mainCSP: 79.0, mainCSPChange: false
12:44:48 PM: info checkNotify- mainMode: auto, mainModeChange: false
12:44:48 PM: info checkNotify- mainFan: on, temStr: on
12:44:48 PM: info checkNotify- mainFan: on, mainFanChange: false
12:44:48 PM: debug checkNotify:enter-
zone 1
12:45:49 PM: info setVents- [Becca Vent], changeRequired: false, new vo: 0, current vo: 0
12:45:49 PM: warn setVents- newVo: 0
12:45:49 PM: debug setVents:enter-
12:44:49 PM: info CHILD Requesting System Reduced Ouput
12:44:49 PM: info setVents- [Becca Vent], changeRequired: false, new vo: 0, current vo: 0
12:44:49 PM: warn setVents- newVo: 0
12:44:49 PM: info vent at min VoLocal null
12:44:49 PM: debug zoneEvaluate:exit-
12:44:49 PM: info CHILD zone temp is 80.0°F, cooling setpoint of 77°F is not met, setting vents to 0% output reduction false
12:44:49 PM: debug setVents:enter-
12:44:49 PM: info Parent needs offset
12:44:49 PM: info CHILD evaluateVents Cooling
12:44:49 PM: info Main HVAC is on and cooling
12:44:49 PM: info zoneEvaluate- system start up, evaluate: true
12:44:49 PM: info no change in state
12:44:49 PM: info Zone is enabled no zone climate selected always enabled
12:44:48 PM: info Zone output redution disabled
zone 2
12:46:55 PM: info Zone output redution disabled
12:45:49 PM: error java.lang.NullPointerException: Cannot invoke method toInteger() on null object @ line 1040
12:45:49 PM: warn setVents- newVo: null
12:44:48 PM: debug setVents:enter-
12:44:48 PM: info Parentdose not need offset
12:44:48 PM: info Main HVAC is on and cooling
12:44:48 PM: info zoneEvaluate- system start up, evaluate: true
12:44:48 PM: info no change in state
12:44:49 PM: info CHILD Clearing System Reduced Ouput
12:44:49 PM: info setVents- [Master bath Vent], changeRequired: true, new vo: null, current vo: 42
12:44:48 PM: info CHILD zone dose not need offset
12:44:48 PM: info CHILD evaluateVents Cooling
12:44:48 PM: debug zoneEvaluate:enter-- parameters: [msg:stat, data:[initRequest:false, mainState:cool, mainStateChange:true, mainMode:auto, mainModeChange:false, mainCSP:79.0, mainCSPChange:false, mainHSP:72.0, mainHSPChange:false, mainOn:true]]
12:44:48 PM: info Zone is enabled no zone climate selected always enabled
12:44:49 PM: error java.lang.NullPointerException: Cannot invoke method toFloat() on null object @ line 904
12:44:49 PM: debug levelHandler:enter-
zone 3
12:45:48 PM: error java.lang.NullPointerException: Cannot invoke method toInteger() on null object @ line 1040
12:45:48 PM: warn setVents- newVo: null
12:45:48 PM: debug setVents:enter-
12:44:48 PM: debug zoneEvaluate:exit-
12:44:48 PM: info CHILD Requesting System Reduced Ouput
12:44:48 PM: info CHILD zone temp is 79.0°F, cooling setpoint of 79°F is met, setting vents to null%
12:44:48 PM: warn setVents- newVo: null
12:44:48 PM: info Parent needs offset
12:44:48 PM: info CHILD zone needs offset
