Attribute change in Tile
Hello there, I’m new here to Smartthings. I just read the documentation and now I want to make a Device Type Handler. Now I made a Device Handler with a GUI ( Tiles ) and on this GUI are two Buttons. One to increase the temperature and one to decrease. Now I made the functions ( tempup and tempdown ).
Now I got 2 Problems.
  1. I included the Thermostat capability. I can change the Values of own created attributes by sendEvent on the installed method and then this value is shown in the smartthings app. But I can’t change the value of attributes that are already defined by the capability. For Example: thermostatSetpoint. Do I have to initialize these attributes I need of a capability first or how can I use them?
  2. I can change the values of my own attributes on the installed method. But when I try to change the Value in another function like “tempup” or “tempdown”, the Value don’t change in the Smartthings app.
I hope you understand what I mean, otherwise just ask.
Hopefully someone can help me.
Code:
metadata {
	definition (name: "SmartThermostatDeviceHandler", namespace: "Dany Van der Meij", author: "Dany Van der Meij") {
		capability "thermostat"
        attribute "ThermostatSetpoint", "Number"
        attribute "ThermostatHumidity", "Number"
        attribute "ThermostatAirquality", "Number"
        command "tempUp"
        command "tempDown"
	simulator {
		// TODO: define status and reply messages here
	tiles (scale: 2) {
		multiAttributeTile(name:"thermostatFull", type:"thermostat", width:6, height:4)
    		tileAttribute("device.ThermostatSetpoint", key: "PRIMARY_CONTROL") {
        		attributeState("temp", label:'${currentValue}', unit:"dF", defaultState: true)
    		tileAttribute("device.ThermostatSetpoint", key: "VALUE_CONTROL") {
            	attributeState("VALUE_UP", action: "device.tempUp")
        		attributeState("VALUE_DOWN", action: "device.tempDown")
    		tileAttribute("device.ThermostatHumidity", key: "SECONDARY_CONTROL") {
       		 attributeState("humidity", label:'${currentValue}', unit:"%", defaultState: true)
    		tileAttribute("device.thermostatOperatingState", key: "OPERATING_STATE") {
        		attributeState("idle", backgroundColor:"#00A0DC")
        		attributeState("heating", backgroundColor:"#e86d13")
        		attributeState("cooling", backgroundColor:"#00A0DC")
    		tileAttribute("device.thermostatMode", key: "THERMOSTAT_MODE") {
        		attributeState("off", label:'${name}')
        		attributeState("heat", label:'${name}')
       	 		attributeState("cool", label:'${name}')
        		attributeState("auto", label:'${name}')
        standardTile('temperatureTile', 'device.ThermostatSetpoint', defaultState: true, width: 2, height: 2, backgroundColor: "#e86d13")
        	state "ThermostatSetpoint", label: '${currentValue}'
		standardTile('humidityTile', 'device.ThermostatHumidity', defaultState: true, width: 2, height: 2)
        	state "ThermostatHumidity", label: '${currentValue}'
        standardTile('airqualityTile', 'device.ThermostatAirquality', defaultState: true, width: 2, height: 2)
        	state "ThermostatAirquality", label: '${currentValue}'
        standardTile('thermostatmodeTile', 'device.thermostatSetpoint', defaultState: true, width: 2, height: 2)
        	state "thermostatSetpoint", label: '${currentValue}'
        standardTile("refresh", "command.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2)
            state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
        main('thermostatFull')
        details('thermostatFull','temperatureTile', 'humidityTile', 'airqualityTile', 'thermostatmodeTile', 'refresh')
def installed()
	log.debug "Installed"
    sendEvent(name: "ThermostatSetpoint", value: 20)
    sendEvent(name:"ThermostatHumidity", value: 41)
    sendEvent(name: "ThermostatAirquality", value: 400)
    sendEvent(name: "thermostatSetpoint", value: 42)
	initialize()
def tempUp()
	log.debug "Tempup()"
    sendEvent(name: "ThermostatSetpoint", value: 30)
def tempDown()
	log.debug "Tempdown()"
    sendEvent(name: "ThermostatSetpoint", value: 40)
def initialize()
	log.debug "Initialize"
def poll()
	log.debug "Executing poll"
def updated()
	log.debug "updated()"
def parse(Map description) {
/************** Betriebsfunktionen **************/
def auto()
	log.debug "auto()"
def cool()
	log.debug "cool()"
def emergencyHeat()
	log.debug "emergencyHeat()"
def fanAuto()
	log.debug "fanAuto()"
def fanCirculate()
	log.debug "fanCirculate()"
def fanOn()
	log.debug "fanOn()"
def heat()
	log.debug "heat()"
    def temp = device.currentState("ThermostatSetpoint").value;
    log.debug "Temp: ${temp}"
    setThermostatSetpoint(temp)
def off()
	log.debug "off()"
/************** Setter Methods **************/
def setCoolingSetpoint(Number setpoint)
	log.debug "setCoolingSetpoint()"
    setThermostatSetpoint(setpoint)
def setHeatingSetpoint(Number setpoint)
	log.debug "setHeatingSetpoint()"
def setThermostatFanMode(Enum fanmode)
	log.debug "setThermostatFanMode()"
def setThermostatMode(Enum mode)
	log.debug "setThermostatMode()"
def setThermostatSetpoint (Number setpoint)
	log.debug "setThermostatSetpoint()"
    sendEvent(name: "ThermostatSetpoint", value: setpoint)
    log.debug "Heating Sepoint: ${setpoint} new Setpoint: ${device.currentState("ThermostatSetpoint").value}"
First of all… Please learn to properly share code in the Forum using Markdown.
  • Either link to a GitHub Repo or a Gist.
  • Or surround your code with three back quotes:
def method() {
   do stuff
That was done like this:
…Terry.
Hello, thanks, I did it. Now, can you help me with my other problems?
I would be very grateful
angry_101_dalmations
Next: Throughout your code.. Capitalization MATTERS.
Attribute names do not have initial caps.
Use exactly the capitalization shown here: http://docs.smartthings.com/en/latest/capabilities-reference.html#thermostat
My general advice?
Please start with a much simpler DTH to experiment with … like a Virtual Switch. Modify it’s code a bit at a time until you break it, then go back and fix it, repeat.
Do not start with a brand new complex DTH like a Thermostat.
But find a template example Thermostat and modify it.
This is not the attribute thermostatSetpoint from the capability. When you look into the code you see that I created this attribute by myself.
Ah! In that case, I would really recommend that you go even further and give the Attribute a much more unique name. SmartThings has a pre-processor and that could ignore case in some places! Even if not, the code is confusing.
Call it danThermoSetpoint or something really obvious!
I’m using my own attributes because when I try to use the attributes from the capability, the value shown in the Tiles is always 0. Even when I do:
With my own Attributes it works, but not for the Capability Attributes.
