I am fairly new to smartthings and would like to start tinkering with the Shield for the Arduino Mega. I have looked over all the comments on the Arduino Libraries and have installed what I found, but I cannot compile any example sketches. I keep getting an error “no matching function for call to SmartThings::SmartThings(int,int,void(&)(string))”. When I select Uno as my board it compiles just fine, but when I go back to Mega it gives me the error. Makes me think the library is for Uno only, any suggestions?
Todd, yes, that was the only library I was able to find. The Smartthings documentation site link didn’t work.
Are you trying to compile the ST_Anything example?
Can you paste in the output with the errors?
@jelloj1 Which version of the Arduino IDE are you using? v1.6.6 (current version, IIRC) has a bug in it which throws various compiler errors. Please use v1.6.5 (or possibly the latest “Hourly Build” of v1.6.7.)
v1.6.5 has been thoroughly tested with my ST_Anything project and my version of the ThingShield library. Please read the ReadMe thoroughly on my GitHub repository as it explains quite a bit about using a Mega 2560 with the ThingShield.
It is version 1.6.6. The weird thing is that it compiles just fine if I select UNO as my board, but with MEGA it gives me the error. I will look at the read me file and see if I am missing anything since I am using the MEGA board. If that doesn’t yield anything I will try an earlier version of the IDE, thanks everyone.
This is the error output from the Arduino IDE:
Arduino: 1.6.6 (Windows 7), Board: “Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)”
stLED:47: error: no matching function for call to ‘SmartThings::SmartThings(int, int, void (&)(String))’
SmartThings smartthing(PIN_THING_RX, PIN_THING_TX, messageCallout); // constructor
C:\Users\Jay\AppData\Local\Temp\arduino_b3363da30f5e48b5a71d125a454395b1\stLED.ino:47:66: note: candidates are:
In file included from C:\Users\Jay\AppData\Local\Temp\arduino_b3363da30f5e48b5a71d125a454395b1\stLED.ino:32:0:
C:\Users\Jay\Documents\Arduino\libraries\SmartThings/SmartThings.h:171:2: note: SmartThings::SmartThings(SmartThingsSerialType_t, void (*)(String), String, bool)
SmartThings(SmartThingsSerialType_t hwSerialPort, SmartThingsCallout_t *callout, String shieldType = “GenericShield”, bool enableDebug = false);
C:\Users\Jay\Documents\Arduino\libraries\SmartThings/SmartThings.h:171:2: note: no known conversion for argument 3 from ‘SmartThingsCallout_t {aka void(String)}’ to ‘String’
C:\Users\Jay\Documents\Arduino\libraries\SmartThings/SmartThings.h:111:7: note: constexpr SmartThings::SmartThings(const SmartThings&)
class SmartThings
C:\Users\Jay\Documents\Arduino\libraries\SmartThings/SmartThings.h:111:7: note: candidate expects 1 argument, 3 provided
exit status 1
I get this error regardless of what sample program I try to run
Can you try it with the 1.6.5 IDE?
Was this ever resolved? I get the same compile error as well with Meg board config.
I’m using IDE 1.6.7
Tested on IDE 1.6.5 same error with Mego board config and Uno board config compiles successfully.
I just remembered this issue…
Please look through any/all of your Arduino source code for a string that contains three exclamation points in it… “!!!”
This string is known to cause issues only with an Arduino Mega for some reason. In some of my old code, I used to have Serial.print statements that contain a string that included !!!. Changing these to a single “!” solved the issue. I already updated my GitHub repository to resolve this. If you found another case, please let me know so I can fix it.
Sounds like you have narrowed it down but it’s time to show what little I know about code. I am using your 24 zone arduino sketch and I don’t see any line of code string with 3 exclamations !!! in the code. Am I looking in the wrong place when you say “Arduino source code”?
On a separate note; I did test on both a mac and windows machine with the same results, Uno board works and Mega fails
line of code of failure = SmartThings Smartthing(PIN_THING_RX, PIN_THING_TX,messageCallout); //constructor
Compile fail error = no matching function for call to ‘SmartThings::SmartThings(int,int,void(&)(String))’
Hmmmm… I do not have a 24 zone sketch as part of the ST_Anything library. Can you please post the sketch you are using. Or send a link to the source code on Github?
I now believe you may be using my version of the SmartThings ThingShield library, but are using somebody else’s Arduino sketch. I can help you make this work with a one line code change, but I need to see the sketch you’re trying to compile.
Have you tried compiling my ST_Anything.ino sketch? It should compile for either the UNO or the MEGA without error.
My apologies… nothing like looking even more foolish.
here the sketch I am trying to use:
- Irrigation Controller 16 Zones With Options for Master Valve and Pump v1
- Simple, elegant irrigation controller that takes advantage of the cloud and SmartThings ecosystem
- Arduino MEGA with SmartThings Shield and 16 relay modules
- Works by receiving irrigation run times from the Cloud and then builds a queue to execute
- Will automatically shut off if power goes out and/or the queue finishes execution
- Updates the Cloud if a station is queued and as each station turns on or off.
- By using the timer library, the CPU remains ready to process any change requests to the queue
- Allocates relay 16 to run a master valve or pump
- Libraries:
- Timer library was created by Simon Monk as modified by JChristensen https://github.com/JChristensen/Timer. Note: if you
- download the library from the source, you must rename the zip file to “Timer” before importing into the Arduino IDE.
- An enhanced SmartThings Library was created by Dan G Ogorchock & Daniel J Ogorchock and their version is required for this implementation.
- Their enhanced library can found at:
- https://github.com/DanielOgorchock/ST_Anything/tree/master/Arduino/libraries/SmartThings
- SoftwareSerial library was default library provided with Arduino IDE
- Copyright 2014 Stan Dotson (stan@dotson.info) and Matthew Nichols (matt@nichols.name)
- Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0 - Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
- ArduinoMEGA Configuration:
- Relays 1-16 are controlled by ArduinoMega pins 21-36, respectively
- An optiona (17th) relay can be added and controlled by pin4 to give 16 zones + master pump valve
- 24V AC power source to run irrigation valves connects to common (middle) contacts on the relay
- Irrigation valve wires use the normally open (NO) contacts on relay
- This code works with “Active HIGH” relays, such as SeeedUino v2 relays.
- To use with “Acitve LOW” relays, such as SainSmart, set isActiveHigh to false
/// ArduinoMEGA Pin Configuration (rough)
/// ______________
/// | SW[] |
/// |[]RST |
/// | AREF |–
/// | GND |–
/// | 13 |–
/// | 12 |–
/// | 11 |–
/// --| 3.3V 10 |----| Run jumper from pin10 to pin3
/// Relay VCC --| 5V 9 |-- |
/// Relay Ground–| GND 8 |-- |
/// --| GND | |
/// --| Vin 7 |-- |
/// | 6 |-- |
/// --| A0 5 |-- |
/// --| A1 ( ) 4 |-- | pin4 Optional Pump/Master Valve
/// --| A2 3 |----| pin3 THING_RX
/// --| A3 2 |-- pin2 THING_TX
/// --| A4 1 |–
/// --| A5 14 |–
/// --| A6 15 |–
/// --| A7 16 |–
/// --| A8 17 |–
/// --| A9 18 |–
/// --| A10 19 |–
/// --| A11 20 |–
/// --| A12 21 |–
/// --| A13 |
/// --| A14 |
/// --| A15 |
/// |_ (54->22) |
/// @note typical relay with normally open (NO) and normally closed (NC) options
/// | |__
/// | ( ) | | ‘NC’ normally closed (not used)
/// | ( ) | / ‘comn’ common (connect 24V power from transformer to here and daisy chain to remaining 7 relays)
/// | ( ) |___| ‘NO’ normally open (connect sprinkler valve wire here)
/// note: the ground from 24V transformer is connected to common ground running to sprinkler valves
/// Typical finished wiring diagram for 16 zones
/// Warning: Connecting a Pump Start Relay is potentially dangerous
/// Warning: Pumps run on 120V or 220V power and incorrect wiring could result in lethal shock or fire hazard!
/// Warning: Work is best done by licensed electrician following local codes.
/// Common terminals are daisy chained together.
/// Sprinkler load wires are connected to NO of respective relays
/// Ground from Sprinkler power supply is tied to the Common Ground Wire from Irrigation Wire Bundle
/// wire [ --from 24V AC Sprinkler Power Supply (-)
/// nut [ --Common Ground wire from Irrigation Wire Bundle (-)
/// | NC |
/// | 1 CMN |===|—from 24V Sprinkler Power Supply (+)
/// | NO |—]---to valve 1
/// | NC | |
/// | 2 CMN |—|
/// | NO |—]---to valve 2
/// | NC | |
/// | 3 CMN |—|
/// | NO |—]---to valve 3
/// | NC | |
/// | 4 CMN |—|
/// | NO |—]---to valve 4
/// | NC | |
/// | 5 CMN |—|
/// | NO |—]---to valve 5
/// | NC | |
/// | 6 CMN |—|
/// | NO |—]---to valve 6
/// | NC | |
/// | 7 CMN |—|
/// | NO |—]---to valve 7
/// Keep wiring until you have wired all16 relays
/// | NC | |
/// | 16 CMN |—|
/// | NO | --]—to valve 16
/// You can do 2X8 relays or 1X16 relays
/// Just keep them in order and be sure to connect the +5V to VCC and GND to GND on each relay unit
/// Also, its recommended to run the relays on auxillary power (use DC current to power relay)
/// The auxillary DC relay power is connected on JD-VCC or other indicated location
/// Depending on the relay board(s) you have, the relay auxillary power may be 5V, 12V or 24V DC. This simplist solution
/// is to purchase and use 5V relays and power them directly from the Arduino.
/// Option: Software Enabled Pump or Master Valve Can Be Connected to Relay 16
/// Warning: Connecting a Pump Start Relay is potentiall dangerous
/// After wiring the optional master valve or pump to zone 16, you must configure the device type to recognize the pump/master valve
/// In the device type, activate the pump tile which will deactivate irrigation zone 16 tile.
/// Software switchable pump/master valve is wired to relay 16.
/// wire {–from 24V Sprinkler Power Supply (-)
/// nut {–Common Ground wire from Irrigation Wire Bundle (-)
/// together {–Common from Pump Start Relay or Master Vavle
/// | NC | |
/// | 16 CMN |—|
/// | NO |— to Pump Start Relay or Master Vavle (low voltage only!!!)
/// **In the device type, activate the pump tile which will automagically deactivate irrigation zone 16 tile.
/// Optional: Add an extra |
Relay for |
/// Master Pump |
/// pin4 – | IN1 NC | |
/// +5V – | VCC CMN | --|
/// GND – | GND NO | — to Master Pump Relay (low voltage only!!!)
#include <SoftwareSerial.h>
#include <SmartThings.h> //be sure you are using the library from ST_ANYTHING which has support for the Arduino Mega
#include <Event.h>
#include <Timer.h>
#define PIN_THING_RX 10
#define PIN_THING_TX 2
#define PIN_THING_LED 13
SmartThingsCallout_t messageCallout; // call out function forward decalaration
//user configurable global variables to set before loading to Arduino
int relays = 16; //set up before loading to Arduino (max = 16 with current code and assumes last relay is a master valve/pump actuator)
boolean isActiveHigh=false; //set to true if using “active high” relay, set to false if using “active low” relay
boolean isDebugEnabled=false; // enable or disable debug in this example
boolean isPin4Pump =false; //set to true if you add an additional relay to pin4 and use as pump or master valve.
//set global variables
Timer t;
int trafficCop =0; //tracks which station has the right of way (is on)
int stations=relays; //sets number of stations reserving 1 relay for the pump.
int relayOn = HIGH;
int relayOff = LOW;
// initialize irrigation zone variables; for readability, zone values store [1]-[23] and [0] is not used
long stationTime[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
int8_t stationTimer[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
int queue[]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; // off: 0, queued: 1, running: 2
int relay[17]; //for readability, zone values store [1]-[16] and [0] is not used
//initialize pump related variables.
int pin4Relay = 4; //pin4 reserved for optional additional relay to control a pump or master valve
boolean isConfigPump = false; // if true, relay16 is used as the pump/master valve switch. Can be toggled by device tye v2.7 and later
char* configPumpStatus = “off”;
char* pin4PumpStatus= “off”;
boolean doUpdate = false;
boolean doPumpUpdate = false;
void setup()
//debug stuff
if (isDebugEnabled) {
// setup debug serial port
Serial.begin(9600); // setup serial with a baud rate of 9600
Serial.println(“setup…”); // print out ‘setup…’ on start
// set SmartThings Shield LED
smartthing.shieldSetLED(0, 0, 1); // set to blue to start
// setup timed actions
t.every(360L1000L, queueManager);// double check queue to see if there is work to do
t.every(60L60L1000L, timeToUpdate); //send update to smartThings hub every 60 min
//check which type of relay is being addressed
if (!isActiveHigh) {
relayOn=LOW;
relayOff=HIGH;
//set up relays to control irrigation valves
int i=1;
while (i<(relays+1)) {
relay[i]= 20+i;
pinMode(relay[i], OUTPUT);
digitalWrite(relay[i], relayOff);
i++;
// set up optional hardware configured pump to pin4 on Arduino
if (isPin4Pump) {
pinMode(pin4Relay, OUTPUT);
digitalWrite(pin4Relay, relayOff);
void loop() {
//run timer
t.update();
if (doUpdate) {
sendUpdate(“ok,”);
doUpdate = false;
if (doPumpUpdate) {
sendPumpUpdate();
//run smartthing logic
smartthing.run();
//process incoming messages from SmartThings hub
void messageCallout(String message)
Serial.print(“Received message: '”);
Serial.print(message);
Serial.println("’ ");
char* inValue[stations+2]; //array holds any values being delivered with message (1-16) and NULL; [0] is not used
char delimiters[] = “,”;
char charMessage[100];
strncpy(charMessage, message.c_str(), sizeof(charMessage));
charMessage[sizeof(charMessage) - 1] = ‘\0’;
inValue[0] = strtok(charMessage,delimiters); //remove first substring as messageType
int i=1;
while(inValue [i-1] != NULL) {
inValue [i] = strtok(NULL, delimiters); //remove remaining substrings as incoming values
i++;
if (strcmp(inValue[0],“on”)==0) { // add new station to queue
if (strcmp(inValue[2],“0”)!=0 && strcmp(inValue[2],“null”)!=0) { //do not add to queue if zero time
int addStation=atoi(inValue[1]);
queue[addStation]=1;
stationTime[addStation]=atol(inValue[2])60L1000L;
scheduleUpdate();
if (strcmp(inValue[0],“off”)==0) {
int removeStation=atoi(inValue[1]);
if (removeStation==trafficCop) {
toggleOff();
//else remove from queue and update queue status to SmartThings
queue[removeStation]=0;
scheduleUpdate();
if (strcmp(inValue[0],“update”)==0) {
scheduleUpdate();
if (strcmp(inValue[0],“allOn”)==0) {
int i=1;
while (i<stations+1) {
if (i != trafficCop) {
if (strcmp(inValue[i],“0”)!=0 && strcmp(inValue[i],“null”)!=0) { //do not add to queue if zero time
queue[i]=1;
stationTime[i]=atoi(inValue[i])60L1000L;
i++;
scheduleUpdate();
if (strcmp(inValue[0],“allOff”)==0) {
allOff();
if (strcmp(inValue[0],“advance”)==0) {
toggleOff();
if (strcmp(inValue[0],“pump”)==0) {
if (strcmp(inValue[1],“0”)==0) {
stations = relays;
if (strcmp(inValue[1],“1”)==0) {
pumpOff();
if (strcmp(inValue[1],“2”)==0) {
pumpOn();
if (strcmp(inValue[1],“3”)==0) {
isConfigPump = true;
digitalWrite(relay[16], relayOff);
configPumpStatus = “enabled”;
stations = relays - 1;
schedulePumpUpdate();
queueManager();
void scheduleUpdate() {
doUpdate = true;
void schedulePumpUpdate() {
doPumpUpdate = true;
//run through queue to check to see if there is work to do
void queueManager()
int i=1;
while (i<25) {
if (trafficCop==0 && queue[i]==1) {
//ready for next in line
trafficCop=i;
toggleOn();
i++;
void toggleOn() {
queue[trafficCop]=2;
smartthing.shieldSetLED(83, 1, 0); //Orange for relay one
if (isConfigPump) {
digitalWrite(relay[16], relayOn);
configPumpStatus = “on”;
if (isPin4Pump) {
digitalWrite(pin4Relay, relayOn);
pin4PumpStatus = “on”;
digitalWrite(relay[trafficCop], relayOn);
t.stop(stationTimer[trafficCop]); // Kill any previously started timers.
stationTimer[trafficCop] = t.after (stationTime[trafficCop],toggleOff);
scheduleUpdate();
void toggleOff() {
digitalWrite(relay[trafficCop], relayOff);
queue[trafficCop]=0; //remove relay from from queue
if (isConfigPump== true) {
if (maxvalue() ==0) {
if (isPin4Pump) {
pin4PumpStatus = “off”;
trafficCop=0; //ready to check queue or watch for new commmonds
scheduleUpdate();
//added allOff as requirement of SmartThings switch capability.
void allOff() {
int i=1;
while(i<stations+1) {
queue[i]=0;
i++;
if (isConfigPump) {
configPumpStatus=“off”;
if (isPin4Pump) {
pin4PumpStatus=“off”;
trafficCop=0;
scheduleUpdate();
void pumpOff() {
if (isConfigPump) {
if (isPin4Pump) {
void pumpOn() {
if (isConfigPump) {
if (isPin4Pump) {
void timeToUpdate() {
scheduleUpdate();
int maxvalue () {
int mxm = 0;
int i=1;
for (i=1; i<stations+1; i++) {
if (queue[i]>mxm) {
mxm = queue[i];
return mxm;
void sendUpdate(String statusUpdate) {
// builds a status update to send to SmartThings hub
String action="";
for (int i=1; i<(stations)+1; i++) {
if (queue[i]==0) {
action=“o”; //off
if (queue[i]==1) {
action=“q”; //queued
if (queue[i]==2) {
action=“r”; //running
statusUpdate.concat (action + i + “,”);
smartthing.send(statusUpdate);
Serial.println(statusUpdate);
statusUpdate = “”;
void sendPumpUpdate() {
if (isConfigPump && configPumpStatus == “enabled”) {
smartthing.send(“pumpAdded”);
if (!isConfigPump && !isPin4Pump) {
smartthing.send(“pumpRemoved”);
if (configPumpStatus == “on” || pin4PumpStatus == “on”) {
smartthing.send(“onPump”);
if (configPumpStatus ==“off” && isConfigPump) {
smartthing.send(“offPump”);
if (pin4PumpStatus ==“off” && isPin4Pump) {
looks like project came from here for the smart sprinkler project
OK, I have figured it out. It appears a change that I made back in October to the SmartThings library has resulted in this issue for non-ST_Anything Arduino apps.
The fix is quite simple… Please modify SmartThings.h as follows - see the last line below where I have commented out the #define DISABLE_SOFTWARESERIAL. Once you add the // comment symbol, save the file and re-compile your sketch. I’ll have to think about the long-term consequences of this change to the rest of my ST_Anything library. But for now, this will get you going!
#elif defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
#define BOARD_TYPE BOARD_TYPE_MEGA
//#define DISABLE_SOFTWARESERIAL //Assume HW Serial is being used. Saves some program space while using HW Serial
Dan,
Thanks so much for nailing this down. It did compile and I have successfully downloaded code to my mega. Now I still have to get the smarttings app widgets working and that is the next step to get all working.
The Smart Sprinkler System that takes advantage of your ST_Anything and projects like the ones you also have to me are what is going to really open up unlimited possibilities.
thanks so much
pete
